Go to Post If I thank everyone that I want to, we might be here for a while - Karthik [more]
Unread 03-02-2017, 16:22
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
Team Role: Coach
Rookie Year: 2012
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Door lock actuator shift?
We have a AM super shifter one of our teams may be using for our climber. We want to spin our intake fast to tangle up the rope than shift into low to climb. We would rather not use air for the shift. A car door lock actuator has the right throw and seems like a good amount of power. Has anyone done this before?
thanks
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 03-02-2017, 16:30
Jonny_Jee's Avatar
Jonny_Jee Jonny_Jee is offline
FRC #2085 (Robodogs)
Rookie Year: 2012
Jonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to beholdJonny_Jee is a splendid one to behold
Re: Door lock actuator shift?
You could use the shifter servos AndyMark sells instead. I haven't had any problems with them in the past.
http://www.andymark.com/Servo-p/am-0010.htm
Keep It Simple Silly!
Unread 03-02-2017, 16:38
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We tried that once but it didn't work well (especially while not moving) and then the servos broke. We swapped over to pneumatics after that event and never looked back.
There was a thread on this topic a few months back that looked at the feasibility of using door lock actuators though I never saw the conclusion or if anyone ever did any testing on it. I'd be interested to know how well it works personally, there are many years where our shifters are the only pneumatics on our robot and it would be nice to save the weight and not worry about air leaks.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Any particular reason you don't want to use air?
I've seen some pretty big problems in the past with the servo versions, including sticking and binding, and even stripping out the servos.
Unread 04-02-2017, 07:51
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
Rookie Year: 2012
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
thanks
We've been experimenting with door lock actuators for a couple of years now but haven't had one on the competition robot yet. It's hard to resist a 3/4" throw electric linear actuator for $5.
They definitely provide enough force for shifting (in our experience) but tolerate being stalled about as much as a RS-550, meaning not well. We have not tried detecting stall and backing off on the command to maintain position yet. These actuators backdrive easily and even the accordion boot over the shaft is enough to return the throw to roughly center position.
