Go to Post I realize that I've been drawn into the trap of thinking that this is about robots and scores and winning. Reboot. Remember why we do what we do. - Mr. Van [more]
Unread 03-02-2017, 18:54
koreamaniac101's Avatar
koreamaniac101 koreamaniac101 is offline
Founder and Team Leader
AKA: Soohan Kim
FRC #5938 (Razor Steel Robotics 4-H Club)
Team Role: Leadership
Rookie Year: 2016
koreamaniac101 is an unknown quantity at this point
Using the Raspberry Pi for Vision Processing
So I am slightly lost on how to use the raspberry pi 3 for vision tracking. We are using a Logitech USB Camera, and we are using GRIP as our vision processing program.
We have Raspbian installed on the Pi. I checked WPILib for processing on an ARM coprocessor:
https://wpilib.screenstepslive.com/s...rm-coprocessor
I saw the "Building Java" part, and i am completely lost as to the purpose and procedure of this section. (What are Maven Artifacts? Gradle Build?)
I also tried building Java on the Pi, from this link:
https://github.com/wpilibsuite/Visio...mples/releases
But I got lost at the part where they ask you to actually run and build the code. Should I be running this directly from the Pi? or from a windows machine?
If anyone could set me on the correct path, it would be great.
UPDATE: Through the instructions from the links above, I managed to get Gradle to make a build of the sample files. I then moved the ZIP File from the output folder to my Pi. But now i have no idea what to do with "CameraVision.zip". All the extracted files are a jar file, a .so file, and a text file.
2016 MAR Hatboro-Horsham District Event Rookie All-Star Award
2016 MAR Seneca District Event Rookie Inspiration Award
2016 MAR District Championships Rookie Inspiration Award
