Go to Post Practice. Don't leave home without it. - JesseK [more]
Unread 03-02-2017, 19:32
18gliccolt 18gliccolt is offline
FRC #6164
18gliccolt is an unknown quantity at this point
Programming the ADIS_16448 IMU for mecanum field oriented driving
I'm one of the programmers on team 6164. This is my first time programming for FRC although I've done a bit of general programming before.
I want to get field oriented driving for our robot with mecanum wheels. The way I understand it is you pass the imu.getAngle() to mecanumDrive_Cartesian. I also think that the ADIS 16448 uses the magnetic field of the earth to get the angle value. What I want it to do is, when the robot starts set the angle to 0 and go from there. That way everything is relative to the angle the robot starts in. Since I couldn't find anything to set the IMU to 0, I get the angle on startup and set that to a variable then subtract that from the new readings. Everything seems right mathematically (unless I'm missing something huge ) but the bot is very jerky. Even if i give the mecanum drive method the angle straight from the IMU the bot is still jerky. If i set the angle a constant of 0 then it drives much smoother but its not field oriented which is what i want.
here is what i have for code so far:
Code:
package org.usfirst.frc.team6164.robot;
import edu.wpi.first.wpilibj.PowerDistributionPanel;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.TalonSRX;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.GenericHID.Hand;
import edu.wpi.first.wpilibj.Joystick.AxisType;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import org.usfirst.frc.team6164.robot.commands.ExampleCommand;
import org.usfirst.frc.team6164.robot.subsystems.ExampleSubsystem;
import edu.wpi.first.wpilibj.PWM;
import com.ctre.CANTalon;
import com.analog.adis16448.frc.ADIS16448_IMU;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
	public static final ExampleSubsystem exampleSubsystem = new ExampleSubsystem();
	public static OI oi;
	CANTalon BL = new CANTalon(1);
	CANTalon BR= new CANTalon(2);
	CANTalon FR= new CANTalon(3);
	CANTalon FL= new CANTalon(4);
	RobotDrive drive = new RobotDrive(FL,BL,FR,BR); //2 motor driver
	Joystick stick = new Joystick(0);
	ADIS16448_IMU imu = new ADIS16448_IMU();
	double heading;
	boolean setHeading = true;
	Command autonomousCommand;
	SendableChooser<Command> chooser = new SendableChooser<>();
	 * This function is run when the robot is first started up and should be
	 * used for any initialization code.
	@Override
	public void robotInit() {
		oi = new OI();
		chooser.addDefault("Default Auto", new ExampleCommand());
		// chooser.addObject("My Auto", new MyAutoCommand());
		SmartDashboard.putData("Auto mode", chooser);
		FL.setVoltageRampRate(50);
		FR.setVoltageRampRate(50);
		FR.setInverted(true);
		BL.setVoltageRampRate(50);
		//BL.setInverted(true);
		BR.setVoltageRampRate(50);
		BR.setInverted(true);
	 * This function is called once each time the robot enters Disabled mode.
	 * You can use it to reset any subsystem information you want to clear when
	 * the robot is disabled.
	@Override
	public void disabledInit() {
	@Override
	public void disabledPeriodic() {
		Scheduler.getInstance().run();
	 * This autonomous (along with the chooser code above) shows how to select
	 * between different autonomous modes using the dashboard. The sendable
	 * chooser code works with the Java SmartDashboard. If you prefer the
	 * LabVIEW Dashboard, remove all of the chooser code and uncomment the
	 * getString code to get the auto name from the text box below the Gyro
	 * You can add additional auto modes by adding additional commands to the
	 * chooser code above (like the commented example) or additional comparisons
	 * to the switch structure below with additional strings & commands.
	@Override
		autonomousCommand = chooser.getSelected();
		 * String autoSelected = SmartDashboard.getString("Auto Selector",
		 * "Default"); switch(autoSelected) { case "My Auto": autonomousCommand
		 * = new MyAutoCommand(); break; case "Default Auto": default:
		 * autonomousCommand = new ExampleCommand(); break; }
		// schedule the autonomous command (example)
		if (autonomousCommand != null)
			autonomousCommand.start();
	 * This function is called periodically during autonomous
	@Override
	@Override
	public void teleopInit() {
		// This makes sure that the autonomous stops running when
		// teleop starts running. If you want the autonomous to
		// continue until interrupted by another command, remove
		// this line or comment it out.
			autonomousCommand.cancel();
		drive.setSafetyEnabled(false);
	 * This function is called periodically during operator control
	@Override
		if (setHeading){
			heading = imu.getAngle();
			setHeading = false;
		System.out.println("percived heading"+ (imu.getAngle()-heading));
		System.out.println("raw angle"+imu.getAngle());
		System.out.println("heading "+heading);
		drive.mecanumDrive_Cartesian(stick.getX()/2, stick.getY()/2, stick.getRawAxis(4)/2, imu.getAngle()-heading);//imu.getAngle()/2);
		Timer.delay(.01);
	 * This function is called periodically during test mode
	@Override
	public void testPeriodic() {
		LiveWindow.run();
