Go to Post Every year, 118 inspires our team to dream for the stars, and land on mars. If 118 wasn't there we wouldn't be off the ground. Think about it every superstar has critics. Keep doing what you do 118. - xSAWxBLADEx [more]
Unread 03-02-2017, 23:45
Superhamster Superhamster is offline
FRC #7548
Rookie Year: 2016
Superhamster is an unknown quantity at this point
Unable to push code
Hello all! I've recently had the problem that I cannot push code to the robot the error message is
build.xml:108 Assertion failed: property 'roboRIOFound' doesn't exist in this project. roboRIO not found, please check that the roboRIO is connected, imaged and that the team number is set properly in Eclipse.
I have tried rebooting the robot installing the latest jdk and updated everything as well, this seems to only be a problem on my computer because other people can push code to the robot just fine without the error. Additionally, I am able to see the robot online through the driver station and going to the roboRIO-2850-FRC.local and pull up the web page so its not a problem specifically with the robot itself.
Thanks for your help!
Unread 04-02-2017, 10:40
FRC #7548
Rookie Year: 2016
Re: Unable to push code
I forgot to mention but I also changed the team number. And I tried to make a new project however I still get the same error.
Unread 04-02-2017, 10:52
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Can you post the full output. Have you tried disabling your firewall?
Unread 04-02-2017, 12:43
FRC #7548
Rookie Year: 2016
Buildfile: C:\Users\All Sparks\workspace\PLZWORK\build.xml
Trying to override old definition of task classloader
clean:
compile:
[mkdir] Created dir: C:\Users\All Sparks\workspace\PLZWORK\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\All Sparks\wpilib\java\current\lib\WPILib.jar;C:\Users \All Sparks\wpilib\java\current\lib\NetworkTables.jar;C :\Users\All Sparks\wpilib\java\current\lib\opencv.jar;C:\Users \All Sparks\wpilib\java\current\lib\cscore.jar to build
[javac] Compiling 1 source file to C:\Users\All Sparks\workspace\PLZWORK\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\All Sparks\workspace\PLZWORK\dist
[mkdir] Created dir: C:\Users\All Sparks\workspace\PLZWORK\build\jars
[echo] [athena-jar] Copying jars to build/jars.
[copy] Copying 4 files to C:\Users\All Sparks\workspace\PLZWORK\build\jars
[jar] Building jar: C:\Users\All Sparks\workspace\PLZWORK\dist\FRCUserProgram.jar
get-target-ip:
[echo] Finding roboRIO, please ignore any [hostinfo] error messages
[echo] Trying mDNS: roboRIO-2850-FRC.local
[echo] Trying USB: 172.22.11.2
[echo] Trying DNS: roboRIO-2850-FRC.lan
[echo] Trying Static Ethernet: 10.28.50.2
[hostinfo] Error retrieving remote host information for host:roboRIO-2850-FRC.lan.
BUILD FAILED
C:\Users\All Sparks\wpilib\java\current\ant\build.xml:108: Assertion failed: Property 'roboRIOFound' doesn't exist in this project.
Total time: 32 seconds
And I have my firewall completely disabled
Unread 04-02-2017, 13:46
FRC #7548
Rookie Year: 2016
I figured out a solution that worked for me. What I did was I plugged in my laptop via Ethernet to the RIO and disabled the wireless connection then pushed the code and it seem to be able to find the RIO. After that I switched back the to wireless connection and it seemed to fix itself. Such an odd solution....
Unread 04-02-2017, 19:51
MuskieProgramme MuskieProgramme is online now
FRC #6420
Rookie Year: 2014
MuskieProgramme is an unknown quantity at this point
I had this problem when I switched RIOs. We were programming one RIO for the practice robot while the build team worked on the main RIO, then I got this when I tried to program the other RIO. It worked eventually, and I am fairly certain it was solved by unplugging the radio's Ethernet and reconnecting it to the RIO.
