Not able to connect with DS but able to deploy code
I am having a connection issue that only affects the Driver Station from connecting to the roboRIO. All my teammate's computer's do not have this problem. I am able to ping the roboRIO via command prompt and deploy LabVIEW code to the roboRIO-1094-FRC.local address over wifi. When I bring up the driver station the radio and roboRIO LEDs on the diagnostics page show green but I cannot get the communications LED (the one beside robot code) to turn green. I have tried wifi, Ethernet, and USB connections with no success. I have made sure my computer's IP address is automatic and all network connections except the one in use are disabled. I do not believe I had this issue last year.
Any suggestions? Thank you! |
Re: Not able to connect with DS but able to deploy code
Check to make sure you have the team number set in the driver station settings.
The team number has been set. I am not sure if I have tried re-typing it while I am trying to connect yet though. Thank you.
Also doublecheck your firewall is allowing the driverstation through.
