Go to Post I can tell you that I feel happiest when I am giving or doing for others. I do not expect anything in return but just knowing that I can make things better, in my small way, makes me happy. - Steve W [more]
Unread 04-02-2017, 07:15
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Climber legality and safety.
Our current plan is to create a climber that is basically a cylinder that has bolts sticking out of it (like a stegosaurus tail). It would be spinning at around 300rpm. An mounted directly above the wheels on one side of a KOP drivetrain.
There are a lot of exposed spinning climbing mechanisms this year, and I was wondering about meeting safety requirements. Would it have to be shielded if the field? Warning labels? What should we expect?
Unread 04-02-2017, 08:11
mjc49's Avatar
mjc49 mjc49 is offline
Coach - Team 3042
AKA: Mike
FRC #3042 (Cobalt Catalyst)
Team Role: Coach
Rookie Year: 2013
mjc49 is an unknown quantity at this point
Re: Climber legality and safety.
The rule that applies here is R06. If everything is pointing in the same direction, that is more likely to be approved by your inspector than protrusions going at multiple angles (like a jack for you old timey folks) as that could create a pinch point.
(2013-Current) Coach-Team 3042 Cobalt Catalyst, MN North Star Regional Winners (2014 w/2177 & 4778, 2016 w/2175 & 3130)
2017 - LRI: MN North Star Regional
Unread 04-02-2017, 08:24
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Rookie Year: 2012
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
This is going to be a very common feature on many robots this year, and is going to be one of the toughest calls made by LRI's. Usually, the terms "sharp" and "300 rpm" scream guards. But this year putting guards around a climbing mechanism has the potential to limit the mechanism's effectiveness.
I have a fear that these cases will be handled on an event to event, and robot to robot basis with each LRI making their own judgement calls. As an LRI in training, I would love to hear some guidance from Al about how these mechanisms should be treated.
In order to increase the odds that your mechanism will be legal, make sure to take some steps to increase the level of safety of the mechanism. Being able to show an inspector "we did X, Y, and Z to make this mechanism safe" will go a long ways towards getting a thumbs up for your robot.
Some things I'd try to do:
- Demonstrate the climber is software protected. In other words, make it so that the climber won't go off without the driver wanting it to. This could include a safety button or something similar that won't allow the climber to go without the button being hit first.
- Increase the "stegasauraus spike" diameter to the maximum functional diameter you can. If I see a punch of needle-like spikes on your climber, I'd feel a lot worse than if I saw 1/4" protrusions.
-Try to mount your climber in a way such that there are no pinch points. Make it difficult to get your hand caught in your climber.
-Along those same lines, put all the guards in place that you can that won't compromise functionality. A guard that doubles as a guide for the rope would seem to be a good design choice.
I really hope there is some clarity on how these cases will be handled.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 04-02-2017, 08:50
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Preferably some sort of hard lock to (like a pin) to keep it from going when you're not on the field or intentionally testing it somewhere
Kinda like the safety locks team had on their catapults in 2014 or on their can grabbers in 2015.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016) | FTC Referee (2017)
Academic Student (Forever)
Unread 04-02-2017, 09:34
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Rookie Year: 2012
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
There is a distinct difference between many this climber and many of the catapults/can grabbers: this mechanism required motors to put power into the mechanism to make it move whereas many of the catapults and can grabbers required power to keep them from moving. When the robot isn't on, a spring loaded mechanism is a lot scarier than a motor powered one. A pin might still be a good idea, but it would only be useful when you want to test one mechanism on the robot and not worry about the climber starting up. You can effectively do the same thing in software by making the driver press two buttons to start the climber instead of one button that could get pressed by accident.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 04-02-2017, 09:37
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
Team Role: Coach
Rookie Year: 2010
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
I find it odd that people are worried about proving the safety of a barbed drum when no too long ago devices known as "harpoon cannons" passed without much issue all over the world.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 04-02-2017, 09:50
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
I mean, it was only one team that needed to pass with harpoons and I wouldn't call their inspection a walk in the park.
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
Unread 04-02-2017, 10:29
Team Role: Coach
Rookie Year: 2010
True, but there were many harpoonesque launchers for climbing last year too. Just the worry on a rotating item when high powered launching devices are in use makes me chuckle a bit.
Andrew Basse
Unread 04-02-2017, 11:25
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Rookie Year: 2007
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Our climber sounds quite similar. I might still like some improvements to it, but we we've put our hands into the bolts as they are spinning (1/4-20 socket heads are the leading edge) and it doesn't really hurt, even. Now if someone had long hair or loose jewelry it would be a problem, but those are problems with or without a climber.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 04-02-2017, 11:41
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
"We put our hands into this relatively fast spinning protruding device, and deemed that it doesn't hurt much" . Hey can you tell me if putting a hand into a spinning saw blade hurts?
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 04-02-2017, 11:56
CalTran's Avatar
MST Rolla Senior
Rookie Year: 2010
Not like anyone's ever going to complain that your robot is too safe.
Unread 04-02-2017, 12:20
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
s_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond reputes_forbes has a reputation beyond repute
When inspectors judge the safety of one of your mechanisms, you get different results depending on which inspector you get. Sometimes you fly through inspection with something that I don't want to stand anywhere near (2014 was a good year for this) and other times you have to spend a lot of time filing down corners that no one will ever touch.
In general, if you've made some sort of effort to make the mechanism safer by adding guards or big bright warning labels, you will have an easier time getting through inspection.
