Go to Post ...the great teams in FRC will probably continue to be great teams. That is because they have great people who embrace the challenge rather than whine about it. - dtengineering [more]
Unread 04-02-2017, 10:30
Yousuf Yousuf is offline
FRC #0564
Yousuf is an unknown quantity at this point
Confused on how to use Encoder
We're trying to use the encoder to make the robot travel a specific distance and trying to figure out how to use a PID controller to keep the both sides of the robot travel at the same speed. Any help or guidance would be much appreciated. We use CANTalon SRX's as our speed controllers for the motors and an SRX Magnetic Encoder.
Unread 04-02-2017, 11:52
T8PineappleSam T8PineappleSam is offline
Jonathan
AKA: Jonathan Zwiebel
FRC #0008 (Paly Robotics)
Team Role: Driver
Rookie Year: 2013
T8PineappleSam will become famous soon enoughT8PineappleSam will become famous soon enough
Re: Confused on how to use Encoder
The Talon SRX's has onboard speed controllers which assist a lot with running PID loops. CTRE does a really good job of documenting their work and I would recommend reading through the software manual http://www.ctr-electronics.com/downl...e%20Manual.pdf and checking out the sample code https://github.com/CrossTheRoadElec/FRC-Examples. The section on closed-loop position control can be found in section 10.1 (page 62) of the manual. Note that to use the onboard processing that the Talon provides, the encoders need to plugged in directly to the data ports on the Talons.
Specific to running any loop through TalonSRX's the first steps would be ensuring the Talon drives the correct direction and that the encoder is wired correctly and returning values.
Code:
talon.setFeedbackDevice(CANTalon.FeedbackDevice.CtreMagEncoder_Relative)
talon.reverseSensor(is_reversed)
talon.reverseOutput(is_reversed)
To run a closed-loop position loop you must set the Talons to position mode, set PID constants, and then set a setpoint.
Code:
talon.changeControlMode(CANTalon.TalonControlMode.Position)
talon.setPID(P, I, D, 0, 0, 0, 0)
talon.setSetpoint(target_distance)
Jonathan Zwiebel
Driver, Project Manager, Programmer [Team 8, Paly Robotics]
2016 Central Valley Regional Finalist and Wildcard, Silicon Valley Regional Quarterfinalist, Curie Division, CalGames Quarterfinalist and Entrepreneurship Award, Capital City Classic Quarterfinalist
2015 Central Valley Regional Entrepreneurship Award, Silicon Valley Regional Entrepreneurship Award, Capital City Classic Semifinalist and Judges' Award
2014 Central Valley Regional, Silicon Valley Regional, Chezy Champs
Last edited by T8PineappleSam : 04-02-2017 at 11:53. Reason: Clarified that encoders need to go through data ports.
