Go to Post If FIRST isn't your life, then you're doing something wrong! - BandChick [more]
Unread 04-02-2017, 10:30
ericalbers ericalbers is offline
ericalbers is an unknown quantity at this point
Reading I2C MXP port on roborio
Trying to read data from Revduino, heres the code,
First the Arduino code, it sets up listening on address 0x51, prints anything it receives, then sends back 11 bytes 'abcdefghijk'.
#include <Wire.h>
void setup()
Wire.begin(0x51); // join i2c bus with address #4
Wire.onReceive(receiveEvent); // register event
Serial.begin(115200);
Serial.print("Hello");
void loop()
delay(100);
void receiveEvent(int howMany)
Serial.print("GotString!");
String rxString = "";
while ( Wire.available() > 0 )
char n=(char)Wire.read();
if(((int)n)>0) //((int)(' ')))
rxString += n;
Wire.write("abcdefghijk");
Serial.print(rxString);
Now the java code, its in the thread, creates a I2C with address 0x51 on the MXP port, does a transaction sending 'hellothere\n', which the arduino sees and prints! But it gets a buffer underrun every time, see output after code.
package org.usfirst.frc.team4069.robot;
import java.nio.BufferUnderflowException;
import java.nio.ByteBuffer;
import edu.wpi.first.wpilibj.I2C;
import edu.wpi.first.wpilibj.Timer;
public class ArduinoThread implements Runnable
I2C mi2sdev;
byte[] fromArduino = new byte[512];
public int enabled = 1;
public ArduinoThread()
mi2sdev = new I2C(I2C.Port.kMXP, 0x51); // 4);
public void run()
byte[] buff = "hellothere\n".getBytes();
while (enabled == 1)
try
if (mi2sdev.transaction(buff, buff.length, fromArduino, 11) == false) // mi2sdev.readOnly(fromArduino, 3)==false) //mi2sdev.transaction(buff, 0, fromArduino, 11)==false)
String str = fromArduino.toString();
System.out.println("From: " + str);
else
System.out.println("nothing?");
catch (BufferUnderflowException be)
System.out.println("underflow?");
try
Thread.sleep(1000);
catch (InterruptedException e)
e.printStackTrace();
} // while
}// run()
Arduino OUTPUT:
GotString!hellothere
GotString!hellothere...on and on
Java output:
underflow?
underflow?
underflow?
underflow?
Any idea why the java is not getting abcdefghijk????
Thanks!
