Go to Post Also, there are times when the folks who run this ice cream store don't have the flavors I like. Can you believe that?!!! Although this really frustrates me, I get over this treachery and I still order something. After all, it is ice cream. I like ice cream. - Andy Baker [more]
Unread 04-02-2017, 11:02
adam.behun adam.behun is offline
FRC #4506
adam.behun is an unknown quantity at this point
Vision Processing - GRIP to LabView
Hello,
My team and I are currently working on vision processing for the 2017 SteamWorks competition. We are currently using GRIP in order to recognize the targets for the gear placement in the competition. We have a few questions.
1) We are trying to work with the network tables to use the data from our GRIP program in LabView. We are unsure about how network tables work and how to access them in LabView.
2) Do we connect the camera (Logitech)to the computer or to the RoboRio?
3) Do we connect the computer to the RoboRio via USB cable or Ethernet cable.
4) Do we connect the computer to the RoboRio or the radio?
5) How do we have a live feed of video separate from vision processing for our drivers? What setting do we use in order to not use too much bandwidth at competition?
Teleop code trying to call on GRIP values:
GRIP Code:
Unread 04-02-2017, 11:04
FRC #4506
Re: Vision Processing - GRIP to LabView
Thanks for any help!
Team 4506
Unread 04-02-2017, 11:49
llung llung is offline
FRC #4048
llung is an unknown quantity at this point
hi,
If you're using LabVIEW, why not use the NI vision code instead of using GRIP? Look at the vision processing sample code. It'll get you most of the way there. The camera will be on the robot and all images will go to roboRIO (they can of course also be routed to the console so the user can see them) for processing.
If you insist on using GRIP, be sure to read the "New for 2017" section on screenstepslive https://wpilib.screenstepslive.com/s...8-new-for-2017
Regarding your other questions, I'm not sure what you're referring to when you say "computer" - is this the driver station or some other embedded processor?
With regards to using multiple cameras in LabVIEW, see some of the other threads on the forum.
Good luck
-lou
Unread 04-02-2017, 17:59
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Seriously, Adam, plug the camera into the processor that's using it (the TK1.)
-Colin
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
