Go to Post *referring to Team Titanium's 2012 robot* If only it could play guitar hero at the same time. sigh. - rsisk [more]
  #16   Spotlight this post!
Unread 04-02-2017, 15:50
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Team Role: Leadership
Rookie Year: 2014
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Re: 2.5" CIM Motor stops when climbing
Originally Posted by serdaruluer View Post
Can we find another solution but using gearbox? On the motor side small gear, on the shaft side big gear possible?
Unfortunately I don't think so. You need a bigger reduction for this than you can get from just a chain reduction. Look into a versaplanetary or a banebots planetary. Shipping may be an issue so id try to contact some local teams to see if they have anything laying around.
  #17   Spotlight this post!
Unread 04-02-2017, 16:28
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Based on the math I've done you need about a 9:1 ratio between the CIM motor and the spool (assuming a 1" diameter spool and a ratchet strap-style rope) to lift a fully loaded FRC robot with a decent margin of error (stalls at ~277lbs).
The biggest ratio you can get practically with sprockets (at least easily available ones) is about a 5:1. Now that said, at a 5:1 ratio, if you double the number of motors running it (like adding a second CIM to the opposite side of the system) that 5:1 ratio would work just fine.
Ideally though you would want a proper gearbox that will get you closer to that 9:1 ratio.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
  #18   Spotlight this post!
Unread 04-02-2017, 16:55
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by cbale2000 View Post
Based on the math I've done you need about a 9:1 ratio between the CIM motor and the spool (assuming a 1" diameter spool.
Have you taken into account the effective winch diameter changing as the rope wraps around it?
  #19   Spotlight this post!
Unread 04-02-2017, 17:04
serdaruluer serdaruluer is offline
FRC #6431 (NoktaParantez)
Rookie Year: 2017
serdaruluer is a glorious beacon of lightserdaruluer is a glorious beacon of lightserdaruluer is a glorious beacon of lightserdaruluer is a glorious beacon of lightserdaruluer is a glorious beacon of light
Actually no. Not yet.
  #20   Spotlight this post!
Unread 04-02-2017, 17:22
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
Team Role: Coach
Rookie Year: 2011
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
I have enough power to climb a hill on my bicycle... but I cannot do it quickly. I have to do it very slowly. I must shift to a lower gear ratio in order to do it without getting too tired.
Similarly, the CIM motor has enough power to lift your robot, but it cannot do it quickly. It must be (as we say in the US) "geared down". That means, you will have to use a small gear on the motor shaft to drive a shaft with a larger gear. That same shaft may need a small gear driving another shaft with another large gear. Eventually, the power will be "geared down" enough to lift your robot. A gearbox is another way to do it.
Another thing that could help is to wind your rope onto a smaller diameter. That too will have the effect of "gearing down" the CIM.
Good luck, and I hope we have been helpful to you!
Older, but still somewhat coherent.
  #21   Spotlight this post!
Unread 04-02-2017, 17:50
Ether's Avatar
Rookie Year: 1969
Originally Posted by chapman1 View Post
Eventually, the power torque will be "geared down up" enough to lift your robot. A gearbox is another way to do it.
FTFY. The power out of a gearbox is the same as the power into the gearbox, minus any inefficiency in the gearbox. The power is neither geared up nor geared down.
  #22   Spotlight this post!
Unread 04-02-2017, 18:41
page2067's Avatar
page2067 page2067 is offline
AKA: rick page
FRC #2067 (Apple Pi)
page2067 has a spectacular aura aboutpage2067 has a spectacular aura aboutpage2067 has a spectacular aura about
If obtaining or making gear is box out of question, consider 2 stages of chain reduction - 5:1 each?
  #23   Spotlight this post!
Unread 04-02-2017, 19:13
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
This is what I would suggest. When I was a rookie in 2004, and COTS gearboxes weren't easily available, we had to make a drivetrain using two stages of chain reductions.
You are going to have a hard time doing more than a 3:1 per stage with shaft driven sprockets, since the large tooth counts tend to be plate sprockets. Not sure what size sprockets are easily available there.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
  #24   Spotlight this post!
Unread 04-02-2017, 19:15
cbale2000's Avatar
AKA: Chris Bale
Yes, though it's partially based on the assumption that the strap we're using doesn't wrap exactly straight (which in our testing it typically does not). Even so, you need about an inch of extra strap wrapped up before it starts to cause problems.
If you don't mind the slower speed a 15:1 will give a more comfortable margin.
  #25   Spotlight this post!
Unread 04-02-2017, 19:43
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
To sort of cut through what has been posted -- a single CIM has PLENTY of power to execute a robot climb in a very few seconds. The key factors are -- did you gear down enough so that you can wind up on your drum diameter? How much will your effective drum diameter increase as your rope wraps on top of itself? As a reference point, 3946 is planning to wind some 3/8" line on a 1/2" shaft with a 12.75:1 reduction. Our biggest problem appears to be keeping the rope centered on the robot. Larger diameters will require more aggressive gearing, but will be less susceptible to a wrap or two of line.
  #26   Spotlight this post!
Unread 04-02-2017, 20:00
Ether's Avatar
Rookie Year: 1969
He's not using a strap. He's using a 1.5 cm diameter cord:
Winch diameter is 3cm and rope diameter is 1,5cm.
  #27   Spotlight this post!
Unread 04-02-2017, 23:14
cbale2000's Avatar
AKA: Chris Bale
Didn't see that response.
In that case would depend on how that specific cord wraps up.
The example I gave was based on my own testing and estimates, individual results may vary.
  #28   Spotlight this post!
Unread 04-02-2017, 23:47
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Maximum robot mass = 70 kg. Maximum robot weight = 70 x 9.8 = 690 N.
Effective winch radius = (winch diameter + rope diameter) / 2 = 2.25 cm.
Winch torque needed to lift robot = 2.25 x 690 = 1550 N-cm = 15.5 N-m.
At maximum power, CIM motor torque = 1.2 N-m.
[Note: climbing is fastest at maximum power.]
Climbing time = lift height x robot weight / winch power = 1 meter x 690 N / 330 W = 2.1 sec.
Gear ratio required = 15.5 / 1.2 = 13:1.
Andymark Toughbox with 12.75:1 ratio is in stock as I type this.
All of the above calculations are simplified by neglecting fricition losses. A real robot will require more climbing time.
Richard Wallace
since 2003
Last edited by Richard Wallace : 05-02-2017 at 07:28. Reason: Climbing time calculation
  #29   Spotlight this post!
Unread 05-02-2017, 06:24
Rookie Year: 2017
You've described very well. Thank you all. I'll inform you about the advancements.
  #30   Spotlight this post!
Unread 06-02-2017, 09:27
Rookie Year: 2017
If we can find a gearbox, which model do we need for CIM motor? 15:1 Ratio
Thank you.
