Switching Between Two Cameras in LabView
We have figured out how to run two cameras in LabView (display image from both cameras on Dashboard) at low resolution. But we are trying to figure out a way to use a button on our remote to toggle between cameras, in order to be able to run at a higher resolution. Does anybody have any ideas that could help???
Re: Switching Between Two Cameras in LabView
The Search function of Chief Delphi would be very helpful here.
Did you do anything special to get it working ? Thanks! |
You have to lower the FPS to 10 and set the Compression to 50% in the dashboard on each of the cameras.
