Go to Post Go with a Big Block. The torque is awesome and you cant beat the sound of a built Big Block with a high lift cam and some open headers. A blower would be a nice addition as well. Good luck getting past the inspector. - GBK [more]
Unread 04-02-2017, 17:45
BetaBlues's Avatar
BetaBlues BetaBlues is offline
FRC #5975 (Beta Blues)
Rookie Year: 2016
BetaBlues is an unknown quantity at this point
Code for Ultrasonic Sensor
We have our sensor set up as digital but we are having trouble understanding how to use it. Could someone give us a run down on how to use it? Thanks
Unread 04-02-2017, 19:40
MuskieProgramme MuskieProgramme is offline
FRC #6420
Rookie Year: 2014
MuskieProgramme is an unknown quantity at this point
Re: Code for Ultrasonic Sensor
In general, an ultrasonic sensor gives you a number. The number corresponds to distance. You can use that distance to (for example) calculate how far the robot needs to move, then move that distance.
For more specific instructions, it might be helpful if you specified which ultrasonic sensor you are using.
Unread 06-02-2017, 20:31
BetaBlues's Avatar
Rookie Year: 2016
Our ultrasonic sensor is by Rockwell Automation: HRVL-MaxSonary-EZ MB1013
Unread 07-02-2017, 07:23
pblankenbaker pblankenbaker is online now
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
I'm assuming that your sensor is a MaxBotix MB1013 and that the following is the data sheet for your sensor.
http://www.maxbotix.com/documents/HR..._Datasheet.pdf
Assuming that is your sensor, I would recommend that you start with pins 3, 6 and 7 on the sensor and connect them to an analog input on the roboRIO (refer to the data sheet to determine how they should be connected). The following class could then be used to display readings from the sensor on the SmartDashboard to help you determine how the voltage output from the sensor corresponds to distance.
You will need to determine the constant (VOLTS_TO_DIST) to convert the voltage to a real world distance (if you want to work in real world units instead of voltage).
Code:
package org.usfirst.frc.team868.robot.sensors;
import edu.wpi.first.wpilibj.AnalogInput;
public class DistanceSensor {
  // A MB1013 distance sensor - http://www.maxbotix.com/documents/HRLV-MaxSonar-EZ_Datasheet.pdf
  // (pins 3, 6 and 7 from sensor to analog input 0)
  private static final AnalogInput mb1013 = new AnalogInput(0);
  // TODO - You will need to determine how to convert voltage to distance
  // (use information from the data sheet, or your own measurements)
  private static final double VOLTS_TO_DIST = 1.0;
  public static double getVoltage() {
    return mb1013.getVoltage();
  public static double getDistance() {
    return getVoltage() * VOLTS_TO_DIST;
  public static void updateDashboard() {
    SmartDashboard.putNumber("Distance (volts)", getVoltage());
    SmartDashboard.putNumber("Distance (real)", getDistance());
NOTE: You will need to periodically call the Distance.updateDashboard() command to see the values on the dashboard.
Unread 07-02-2017, 07:28
Coach Seb's Avatar
Coach Seb Coach Seb is online now
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Team Role: Coach
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
This is a great example, thank you!
in a command based situation, would you add this code as its own class, like a subsystem or would you add this to an existing class...?
Unread 07-02-2017, 08:14
FRC #0868
In a command based robot, I would be tempted to refactor the example into its own Subsystem.
However, this could be thought of as a special "read only" type of subsystems. Commands that made use of this subsystem would not need to require() it in their constructors as there isn't a problem if multiple commands take distance measurements at the same time. If two commands both want to get distance measurements, it isn't a problem like it is if two commands both want to manipulate drive motors.
Alternatively, I might be tempted to leave it as its own stand alone class (not make it a subsystem) and just use it as is.
Unread 07-02-2017, 10:19
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Originally Posted by BetaBlues View Post
We have our sensor set up as digital...
Just want to make sure you saw this.
You can do digital via RS232, but it is much easier to do analog.
