Go to Post Unfortunately, there's no special type of transmission that will magically get you past defense. The best way to deal with defense is to practice, regardless of gearing. - connor.worley [more]
Unread 04-02-2017, 17:55
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
Team Role: Leadership
Rookie Year: 2014
nickbrickmaster is an unknown quantity at this point
Robot radio blocking ports
We're having trouble with the robot radios blocking ports they shouldn't be- specifically ports 22, 1180, 5800, 5801, and 5802 (as far as I recall.) This occurs on the OM5P-AC with 2017 firmware, OM5P-AN with 2017 firmware, and OM5P-AN with 2016 firmware.
On all radios, supposedly team-use ports 1180 and 5800+ were blocked. On the OM5P-AN w/ 2016 firmware, port 22 was also inaccessible. Team-use ports were tested by running a custom HTTP dashboard program listening on these ports. While little testing was done with port 22, it was inaccessible to the robotpy deploy tool. I have heard from another team that had the same problem with the Java deploy tool.
I haven't run nmap or similar yet. I'm fairly sure that the radio is the problem, because the HTTP dashboard worked while USB-tethered.
Thanks for any input you may have.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 05-02-2017, 09:57
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: Robot radio blocking ports
When using the programing tool, make sure the firewall checkbox is disabled.
Unread 07-02-2017, 00:52
sfs sfs is offline
Software Engineer
AKA: Steve Siirila
FRC #2220 (Blue Twilight)
sfs is an unknown quantity at this point
In our experience on many radios (both last year's and this year's) that checkbox is ignored and the firewall rules are established unconditionally. As a result, programming the robot over Wi-Fi is not possible since port 22 is blocked.
Unread 07-02-2017, 03:24
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
We are perfectly able to program over wifi using both last years and this years radio.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 07-02-2017, 15:52
sfs sfs is offline
Software Engineer
AKA: Steve Siirila
What firmware version are you using? Have you ever checked the Firewall box in any of your firmware loads or reconfiguration runs? What programming environment do you use? Could you possibly send me the output from a code deployment (assuming you use Eclipse)?
We have tried both 17.0 and 17.2 and use Java via Eclipse and the latest FRC Plugins.
Unread 07-02-2017, 16:16
AKA: אוסטין
Can you post the output from one of your code deployments? I think this is not a firewall issue but rather a mDNS issue.
Unread 07-02-2017, 17:05
sfs sfs is offline
Software Engineer
AKA: Steve Siirila
I don't have access to a robot at present, but the key message was "connection refused" when attempting to connect to port 22 of the RoboRIO.
We've already proven that our radios are blocking port 22 (ssh) by connecting a test laptop running Linux via WiFi to the radio which is in turn connected via Ethernet cable to the RoboRIO. When we remove the radio from the mix and go direct we can get into port 22 of the RoboRIO just fine. We are addressing the RoboRIO by its assigned IP address in both cases.
In the meantime, we've had to program the robot via USB cable. Note that we can bring up the webdashboard and operate the robot via WiFi just fine (since port 22 is not used in those cases).
Thanks guys for offering assistance/insights.
Unread 07-02-2017, 17:39
AKA: אוסטין
Make sure your PC firewall is disabled.
