Go to Post FIRST like life is what you make of it, if you would rather go through FIRST worrying about what other teams do to make their robots, then your destined for disappointment. if you go through FIRST making the most of it doing the best you and your team can then it doesn't matter what other teams do. - Mike Schroeder [more]
Unread 04-02-2017, 18:15
CurlyFries CurlyFries is offline
AKA: Troy Martin
FRC #2512 (Duluth East Daredevils)
Rookie Year: 2014
CurlyFries is an unknown quantity at this point
C++ Joystick Button Error
I'm having an interesting problem with my command based c++ program. Whenever I'm using a created joystick button in the OI source file, I get a very long error message in the driver console, a picture of which is attached to this post. Our joystick is currently plugged in to the correct port, and the button does register on the DS.
This is not our first time with command based, and we are currently creating and using the joystick button as we have had in previous years. There may have been a change this last year that I have not read about? Any help would be greatly appreciated.
Unread 04-02-2017, 18:23
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
Rookie Year: 2013
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: C++ Joystick Button Error
Can you post your relevant code?
Unread 04-02-2017, 18:32
AKA: Troy Martin
Rookie Year: 2014
Here's some screenshots of the oi code.
ID:	21702  Click image for larger version
