Go to Post amazing stuff. - Specialagentjim [more]
Unread 04-02-2017, 18:33
kjgerdes kjgerdes is offline
FRC #3669
Rookie Year: 2017
kjgerdes is an unknown quantity at this point
How do you program the navx mxp in labview?
Right now we are just trying to program our navx mxp in teleop so that when we press a certain button and drive forward it corrects the robot and keeps it straight. If anyone has an example code I could look at that would be great.
Thanks!
Unread 04-02-2017, 18:54
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: How do you program the navx mxp in labview?
I'm unfamiliar with NavX, but what you're talking about would require a PID loop. PID loops take time to tune and basically what you're doing is handing off control of a movement axis to the robot, which is potentially dangerous.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 04-02-2017, 18:58
FRC #3669
Rookie Year: 2017
Ok, so is there a way to make your robot drive straight in autonomous independent mode using the navx? If so do you have an example code I could look at? Thanks!
Unread 04-02-2017, 20:22
FRC #3007
Rookie Year: 2015
You'll need to get an angle from the NavX, is there a library function for that? Once you have an angle, you'll need to feed it in as the process variable of a PID loop. Hook up the PID VI's output to your rotation axis of your drive VI. Then, tune the PID loop.
I recommend using Select from the Comparison palette connected to a button on your joystick so that you can switch between manual and loop control by holding down a button for loop control. Also set it up so that the PID loop reinitializes whenever you press or release the button by using "Equal?" and a feedback node (in this case set it to feed forward).
Team 3007: 2017
Unread 04-02-2017, 22:34
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
See the attached image. What happens is that one side stays at a fixed speed (percent voltage in this case) and the PID loop varies the other side to match it and keep it straight on course.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 05-02-2017, 18:56
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Rookie Year: 2011
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
This is what we did last year. Our code is posted here.
There is a Drive subVI in TeleOp. The "Field Centric" case of the large case structure around the drive code never worked correctly...not enough time for testing it.
Unread 05-02-2017, 22:42
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
Breakaway has done this for a couple of years now.
Because we use the gyro in both modes, we put Get_YPRHfH.vi and store the gyro's position (yaw) into a global in Periodic tasks, and use that global in auto.
The basic principal is that WPI has already provided great algorithms for a x/y control algorithm (Arcade drive). So we use a PID (target gyro angle as the setpoint, the global from the gyro for the process variable, and work out the tuning) as the x input to the Arcade Drive vi, and usually a constant into the y value. We have found that the gyro updates rapidly enough to support this (we've even translated vision analysis into a desired gyro angle because the gyro was updating fast enough and the vision was not.)
The NavX library has updated some since we did this. You could combine this idea with the TeleopRotateToAngle.vi in the navX\Examples folder.
Unread 06-02-2017, 08:41
aeastet aeastet is offline
Programming Mentor
AKA: Tim Easterling
FRC #6043 (Allegan Tigers Robotics)
Team Role: Coach
Rookie Year: 2011
aeastet is an unknown quantity at this point
I just wanted to let you know that you do not need to store the yaw value in a global variable. If you place the Get_YPRHfH.vi directly into the auton it will read automatically if you have the navX main vi placed properly. This is the reason we moved to the action engine for all of our parameters. You can place this vi in as many locations as you need to get the value. This allows you to only read the value when you need it.
If you have questions please let me know.
Team 6043 Allegan Tigers
LabVIEW Developer for Kauai Labs (navX and SF2 Libraries)
http://www.kauailabs.com/
Unread 08-02-2017, 23:34
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
Is there any way to get a continuous fused heading or yaw that doesn't jump at 360/0 or -180/180 degrees? I ask, because we model and correct yaw in an ongoing basis to a modeled value. I know we could reset the gyro if the abs(yaw) > 120 or so, but we want to be able to do a 360 degree closed loop orbit for testing (without sparing at the point where yaw or heading magically jump 360 degrees).
It looks like those values are only being read off a registry, and not calculated in LabVIEW. Is there any way to tell the NavX to put the non-resetting values in those registers?
Unread Yesterday, 09:24
Programming Mentor
AKA: Matthew Shafer
I am attaching the vi's that we used last year to convert the yaw that we got from NavX (-180 to 180 if I remember correctly) to an absolute value (starting at zero and continuous counting from there, so -infinity to +infinity). I'm not sure what you mean by a modeled value, but this should give you an idea of how to do it if this is not what you meant.
Unread Yesterday, 12:41
Programming Mentor
AKA: Tim Easterling
Team Role: Coach
Rookie Year: 2011
OK I developed this a few minutes ago. I can not promise that it works perfectly yet. I am working with the other developers at navX to test it to release to the public. You can try this vi with no guarantees that it will do everything you are asking.
Continuous Angle Tracker.vi
Try it and let me know if you need more capabilities.
Thank you for your input,
Tim
