Go to Post You can also always use the "Report Post" button on each post and that'll dispatch a carrier pigeon to each of our homes...or an e-mail if the carrier pigeons have taken the day off. - Madison [more]
Unread 04-02-2017, 18:57
MuskieProgramme MuskieProgramme is online now
FRC #6420
Rookie Year: 2014
MuskieProgramme is an unknown quantity at this point
Rookie Command Based Feedback
Hello, I am part of a Rookie team (though I have previous Java experience), and would like feedback on my code.
https://github.com/FRC-6420/SteamWorks
Specifically, anything I'm doing that would deviate from the Command Based structure. I also do not have experience using/tuning PID.
I apologize for any code that is just plain messy, I have a tendency to comment something instead of removing it, so I can easily go back - and then leaving it in.
Unread 04-02-2017, 21:43
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Team Role: Coach
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Re: Rookie Command Based Feedback
I need to do the same.... how did you figure the upload to github?
Unread 04-02-2017, 22:33
FRC #6420
Rookie Year: 2014
Short version: I've used github before...
Long version: created an organization, made a blank repository. Opened up github desktop and made a repository in the directory of my code. Edited the remote to point to the blank repository (the URL ending in .git). Installed a Git client for Eclipse from the marketplace (actually multiple, dunno which one I started with). Somehow I got that setup so I now have a "Git Staging" window in eclipse where I can select files to commit and push, I really don't remember how.
Unread 05-02-2017, 04:49
YairZiv's Avatar
YairZiv YairZiv is offline
FRC #5951 (Makers Assemble)
Rookie Year: 2016
YairZiv is an unknown quantity at this point
Send me pm if you need help with github
Unread 05-02-2017, 08:18
Joe Derrick's Avatar
Joe Derrick Joe Derrick is offline
Mentor - Programming
FRC #0319
Rookie Year: 2011
Joe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of lightJoe Derrick is a glorious beacon of light
Greetings, saw your post about command based programming. While I can't comment on vision, the drivetrain aspect looks good.
As far as PID control there are many options for you to take to achieve your objective. What do you want your robot to do autonomously? Drive to a distance? drive straight to a distance?
there are lots of options.
Here are some examples of PID drive control we used for our autonomous is 2015.
recycle rush example PID command
if you look we are actually more concerned with driving straight than exactly how far. there are a few other PID drive commands in their for you to look at.
here is a video of the total auto
Also, during the past season the team has moved to using talon srx's for all of our PID control. It is much easier once you have the setup done. I would recommend it but they are a bit expensive.
Also bear in mind this is just one way to solve a problem, there are probably better and other ways out there,
Good luck!
2010-2017 Mentor Team 319
2012 - Rockwell Automation Award Winner
2014 - Xerox Creativity in Engineering Winner, Archimedes Division
2015 - Rockwell Automation and Gracious Proffesionalism Winner, Tesla Division
2016 - North Shore and UNH District Event Winner, Carson Division
http://www.frc319.com
Unread 05-02-2017, 14:32
FRC #6420
Rookie Year: 2014
I was planning to incorporate "drive straight" into the DriveBase class - automatically activated whenever turnValue is 0. That way, it is also active in TeleOp.
