Go to Post When I saw the title of this thread ("Reverse Robotics"), I thought "what, you get six weeks to take apart a robot or something??" - Katie Reynolds [more]
Unread 05-02-2017, 10:24
NStr NStr is offline
AKA: Nadav Strahilevitz
FRC #3835 (Vulcan)
Rookie Year: 2016
NStr is an unknown quantity at this point
Problem with initializing RobotDrive/Talon objects
Hi,
I encountered a unique problem recently, I only found one thread with a similar problem which they didn't manage to solve(or at least they didn't post how).
I managed to reduce the problem to the point where I initialize my SpeedControllers, either through RobotDrive or Talon(we use Talon SR) object. When I initialized the the RobotDrive object I received an error in the driver station:
Error -52010 NIFPGA: Resource not initialized(something like this).
Additionally, the driver station said that there is no robot code. Surprisingly when I tried uploading a basically identical iterative robot there was no problem and the robot worked fine.
I tried initializing the Talons directly, this time I didn't get the previously mentioned error however there was still no robot code.
I get the following error at the breakpoint of the initialization while debugging the robot:
Can't find a source file at "/var/lib/jenkins/workspace/WPILib/WPILib - Release/hal/lib/athena/DigitalInternal.cpp"
I have tried reimaging, repairing the toolchain, reinstalling the plugins yet nothing seems to solve the problem.
Huge thanks to anyone who tried helping!
Unread 05-02-2017, 23:19
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond reputeozrien has a reputation beyond repute
Re: Problem with initializing RobotDrive/Talon objects
If you are seeing "Error -52010 NIFPGA" in the Driver Station after adding a CANTalon, I would recommend reading section 16.36 in latest Talon SRX Software Reference Manual.
Unread 06-02-2017, 02:51
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
For the lazy
16.36. Adding CANTalon to my C++ FRC application causes the Driver Station log to report: ERROR -52010 NIFPGA: Resource not initialized, GetFPGATime, or similar.
A full example of the crashed call stack is below…
Code:
ERROR -52010 NIFPGA: Resource not initialized GetFPGATime
[Utility.cpp:171]
Error at GetFPGATime [Utility.cpp:171]: NIFPGA: Resource not initialized
at frc::GetFPGATime()
at frc::Timer::GetFPGATimestamp()
at frc::MotorSafetyHelper::MotorSafetyHelper(frc::MotorSafety*)
… this can happen if a CANTalon is constructed before the C++ WPILIB initialization routine is called. At the time of writing, this condition can occur when cleanly creating a C++ Command-based project with the latest Eclipse Plugins. An example workaround can be found here…
https://github.com/CrossTheRoadElec/...74df894f7bbf2d
…demonstrating how to ensure motor controller object is constructed after WPILIB initialization.
C++ Command-based projects generated with latest Robot Builder appears to ensure that motor controller objects are created after WPILIB initialization, and therefore do not cause this failure symptom.
More information on C++ Command-based projects can be found at the FRC screenstepslive page, as this is not maintained by CTRE. https://wpilib.screenstepslive.com
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 06-02-2017, 17:34
ozrien's Avatar
Omar Zrien
AKA: Omar
Originally Posted by euhlmann View Post
For the lazy
Hey that's cheating.
Unread Yesterday, 18:49
FRC #3835 (Vulcan)
Rookie Year: 2016
Wasn't using Talon SRX but I guess the section applies to all Speed Controllers. Anyways this fixed the problem, so thanks a lot!
Unread Yesterday, 18:55
ozrien's Avatar
Omar Zrien
AKA: Omar
That's how good our support is.
