Go to Post When Dean says it's not about the robot he really means it. We're gonna get a speech whether we want it or not and of we complain we'll get even more. - Koko Ed [more]
Unread 05-02-2017, 14:27
Lesafian Lesafian is offline
AKA: Jeremy Styma
FRC #6077 (Wiking Kujon)
Rookie Year: 2016
Lesafian is an unknown quantity at this point
SmartDashboard CameraServer output Flickering
The goal of my code is to be able to switch between vision processing from one camera to another camera.
I have created 2 vision threads, either one or the other is started at one time.
On the SmartDashboard, the camera shows for about a second at 1 fps and 6mbps, then turns off, and repeats. I cannot figure out the issue. Here is the code
Code:
		 * Sync vision variables from thread to thread.
		imgLockGoal = new Object();
		imgLockGear = new Object();
		 * Image used to be processed by a CvSink and outputted through a
		 * CvSource.
		image = new Mat();
		 * Camera used to track vision targets on the boiler.
		cam0 = new UsbCamera("cam0", 0);
		cam0.setResolution(camWidth, camHeight);
		cam0.setFPS(16);
		 * Camera used to track vision targets on the airship.
		cam1 = new UsbCamera("cam1", 1);
		cam1.setResolution(camWidth, camHeight);
		cam1.setFPS(16);
		 * CvSink used to grab and process the image used to output to the
		 * CvSource
		selectedVid = CameraServer.getInstance().getVideo(cam0);
		 * CvSource used to output the processed image onto the SmartDashboard
		 * (CameraServer Stream Viewer).
		outputStream = CameraServer.getInstance().putVideo("Tracking", camWidth, camHeight);
		 * Vision Thread uses the high goal contour filtering to find the best
		 * targets and help lead the robot to the target destination.
		visionThreadHighGoal = new VisionThread(cam0, new VisionClass(), pipeline -> {
			selectedVid.grabFrame(image);
			if (pipeline.filterContoursOutput().size() >= 2) {
				//isTargetFound = true;
				Rect r = Imgproc.boundingRect(pipeline.filterContoursOutput().get(0));
				Rect r1 = Imgproc.boundingRect(pipeline.filterContoursOutput().get(1));
				Imgproc.rectangle(image, new Point(r.x, r.y), new Point(r.x + r.width, r.y + r.height),
						new Scalar(0, 0, 255), 2);
				Imgproc.rectangle(image, new Point(r1.x, r1.y), new Point(r1.x + r1.width, r1.y + r1.height),
				outputStream.putFrame(image);
				synchronized (imgLockGoal) {
					centerX = (r.x + (r1.x + r1.width)) / 2;
					width = (r.x + r1.x) / 2;
			} else {
					//isTargetFound = false;
		}); visionThreadHighGoal.start();
		// TODO: change filters to specify for gears
		 * Vision Thread uses the gear contour filtering to find the best
		visionThreadGear = new VisionThread(cam1, new VisionClass(), pipeline -> {
				synchronized (imgLockGear) {
					// TODO:
			} else {
Thanks!
