Go to Post Don't ever give up on your robot, especially this early in the season. That robot is what you make of it. If you give it your all, something good is bound to come your way. - Amanda Morrison [more]
Unread 06-02-2017, 15:08
AdrianEdgardo47 AdrianEdgardo47 is offline
FRC #4635
AdrianEdgardo47 is an unknown quantity at this point
Problems with PID controll using quad encoders
I have notice every time I plug or unplug a new battery the current PID settings don't work anymore. We're using the encoder via the talonSRX and the library of CANTalon. Do you recommend stop using PID control or and using percentage instead.
Unread Yesterday, 00:57
GavinL GavinL is offline
intensely stares at program
FRC #5726 (RhumBotz)
Rookie Year: 2016
GavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to behold
Re: Problems with PID controll using quad encoders
Are you resetting the encoder values?
Also is there a large difference in the voltage of the battery? Like before it was 8 and now it is 12?
Unread Yesterday, 21:10
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
Rookie Year: 2010
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Could you post your code or explain, in detail, how you are setting the PID values? (How are you setting the PID values via the RoboRIO web dashboard or in code?) Which settings don't work anymore (can you describe the problem in more detail)?
2016 Carson Division Industrial Design Award
2016 San Diego and Orange County, Engineering Inspiration Award
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
