pic: Power Over Ethernet for 2017
Re: pic: Power Over Ethernet for 2017
Thank you for this resource. At out meeting tomorrow, one of the things on the agenda is tackling POE. This should make the process much quicker.
Thanks for this, but a few questions.
1. Will any inspectors not understand this and fail it because they have never seen it? I know that impossible for people to answer but whats your opinion. 2. How reliable is this for vibration? I know last year was a tough game for robots and many people has the radio power fail them, but is this any better? If seems like it would be but do people know for sure? 3. I assume you have to make up your own custom cable by using an RJ-45 end and then just running the conductors where they need to go? Thanks |
2. I didn't have experience with it personally, but I heard lots of anecdotal evidence that this was the go-to solution for vibration-related radio power issues for many teams last season. 3. Yup. It's essentially making a custom/more compact version of one of these cables: https://www.adafruit.com/product/435. There are several available on Amazon as well, if you want to avoid making your own cable. |
We used the Adafruit cable last year and liked it a lot. It's also nice because you can use the POE and barrel jack together and have some redundancy.
Also Mark McLoud posted, in another thread, this cable:
https://www.amazon.com/iCreatin-Pass...416072&sr=8-19 It looks like the adafruit ones. Didn't see it when I posted the picture. Also here is a Q&A saying this sort of thing is legal: https://frc-qa.firstinspires.org/qa/242 Your inspector's understanding of it will vary. |
Awesome ! Thanks.
Just so it's clear to others, that would not result in powering the "PoE" port on the radio as the Ethernet pigtails on those cables do not have power on the pins, the Ethernet cable you connect to the female Ethernet jack on the cable does. |
https://www.amazon.com/SIM-NAT-Split...dp/B01GPRLQCC/ You then plug one of the male plugs directly into the radio, and the second male plug into: https://www.amazon.com/iCreatin-Pass.../dp/B00NRHNPUA The male Ethernet connector goes into the RoboRio, and you use a CAT5 or CAT6 cable to connect the female end into the radio. Thus, the radio receives power directly, and through the Ethernet cable. |
#10
We are planning on using a passive injector similar to these: https://smile.amazon.com/gp/aw/d/B00...ds=passive+poe
We will be removing the barrel plug and soldering in a whip that can plug directly into the VRM. Note passive poe injectors are explicitly allowed per the blue box of R51. So as long as you can explain I would find it hard to fail inspection. The advantage of using something like the one I linked is the reduction of single point failures. There's only one cable plugging into the radio (not an Ethernet cable AND a barrel plug). This is at a cost of a single additional RJ45 connection and the loss of a barrel jack connection (which is the one that usually fails you since there is no positive retention. With the previously linked cables, you're reducing the wires that need to run across the robot, but you have increased the number of failure points as there are two additional RJ45 plugs and one additional barrel jack connection. So reliability has actually gone down. Last edited by otherguy : 07-02-2017 at 10:06. |
#12
FYI, this was covered in LRI training as well. So as long as you really are using a passive injector, your worst case scenario is having to escalate to the LRI.
#14
My power injector uses three connections: 1) roborio RJ45 2) radio RJ45 3) direct wired into VRM after cutting the barrel connector off And an additional Ethernet cable is required from the passive POE injector to the radio. So, four connections altogether. Rob's solution has three total connections (and a few more user modifications). Your solution appears to require one additional Ethernet cable adding RJ45 failure points over and above those others even after you've bypassed the power barrel connector (the user modification is also another potential failure point). Last edited by Mark McLeod : 07-02-2017 at 12:32. |
#15
on both ends. Apparently I've misunderstood the planned implementation. But my comment of things being less reliable assumed you were plugging the dongle with the male barrel into the radio, along with the RJ45 end. The other dongle plugged into the RIO, then a power extension plugged into the female barrel to get to a VRM. An Ethernet cable plugged in to bridge the gap between the two dongles. So to tally things up I was expecting 4 Ethernet connections and 2 power connections. Basically exactly the layout depicted in the last two images of the product page linked. If you're only using one of the cables, cutting the barrel jack off one end, and plugging it into the VRM directly... then I would agree you have one fewer Ethernet connections in this implementation than what I was suggesting. As far as I can tell, nobody suggested this implementation before I posted. In this configuration, you will need the VRM immediately next to the RIO unless you're going to solder extensions to the power leads (which per your comment - you apparently consider to be introducing a failure point). Personally I trust our teams ability to produce reliable solder joints, so I consider this a wash. Quote:
I did consider using a cable like the ones you've linked. My concern with them was the quality of the crimps and whether or not the cables would be twisted pairs or (non-compliant) straight through in the dongle themselves. When I was doing my research at the beginning of the season, the pictures few pictures of the dongles I saw online looked to be questionably small gauge straight through conductors. I didn't have any of these on hand to check myself though. So I made a judgement call to go with the PCB version like the ones I linked earlier. All that said, no need to defend your choices to me. I was just sharing what we were planning on doing since I hadn't seen a POE injector like the one we're using in this thread yet... |
