Command stops my teleop process
Hey there again!
I've been writing my program in a command-based format. This works fine until I try to run a program through a joystick button. My command runs, but halts my teleop program. I am not sure what code is useful in this situation. My TeleopDefault.h and .cpp are my teleop control scheme, and I have other commands like "DropGear" and "DropFuel". When I use a joystick buttons' ->WhenPressed() to run the DropGear command, the TeleopDefault stops and does not return. Any reason for this? Thank you. I will post code if someone knows which files are needed to diagnose the problem. -Eric |
Re: Command stops my teleop process
Sounds like you have a loop in the commands initialize or execute method
If I place a return statement at the end of the execute statement, should I be okay? Because at the moment I have something like this
Code:
TeleopDefault::Initialize(){
//some code
button->WhenPressed(new DropGear());
button->WhenReleased(this);
Are you sure the "button->WhenPressed" stuff should be in initialized?
I'm a bit new to command based but I feel like that should belong in your Execute. It should go in OI, above text is wrong. Last edited by GavinL : Yesterday at 00:53. Reason: wrong info |
It should go in OI, not in a command.
