Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 07-02-2017, 17:34
RoboBucs RoboBucs is offline
FRC #5005
RoboBucs is an unknown quantity at this point
Cool Prgramming Arduino lights in LabView
Hello
I'm working with an Arduino based LED light circuit called (Ethernet Microcontroller, Arduino-Compatible (No PoE) (am-2287)), and I'm trying to integrate it into our LabVIEW code. Does anyone have some advise or a tutorial.
Thanks
Unread 07-02-2017, 20:16
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: Prgramming Arduino lights in LabView
What type of communication would you like to use between the microcontroller and your roboRIO, and is there a reason you can't use the roboRIO to control the lights using code in Periodic Tasks.vi and DIO ports?
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 08-02-2017, 16:33
FRC #5005
We just want to be able to change the colors between red and blue with a button on the joystick or in Labveiw.
Unread Yesterday, 16:09
sraque's Avatar
sraque sraque is offline
AKA: Steve Raque
FRC #2614 (MARS)
sraque is on a distinguished road
Here is what we are doing for this. We are having labview set DIO pins hi or low and we connect those pins to Arduino DIO pins. # of pins you use depends on the number of combinations you want (including off, maybe). Arduino code executes different light code based on status of those pins.
