Go to Post Off time, at a regional? What is that? - DonRotolo [more]
Unread 08-02-2017, 18:38
verlander13 verlander13 is offline
AKA: Ian
FRC #1025 (IMPIS)
Rookie Year: 2015
verlander13 is an unknown quantity at this point
Exclamation Detecting countours
Can anyone explain why my code will not stop once centerX1 is equal to 237?
package org.usfirst.frc.team1025.robot.commands.Vision;
import org.usfirst.frc.team1025.robot.Robot;
import org.usfirst.frc.team1025.robot.subsystems.ChassisS ubsystem;
import org.usfirst.frc.team1025.robot.subsystems.VisionSu bsystem;
import edu.wpi.first.wpilibj.command.Command;
@SuppressWarnings("unused")
public class VisionAuton extends Command {
double centerX1;
double centerX2;
private boolean isCenter = false;
public VisionAuton() {
// Use requires() here to declare subsystem dependencies
// eg. requires(chassis);
requires(Robot.visionSubsystem);
requires(Robot.chassisSubsystem);
// Called just before this Command runs the first time
protected void initialize() {
// Called repeatedly when this Command is scheduled to run
protected void execute() {
synchronized (Robot.visionSubsystem.imgLock) {
Robot.visionSubsystem.centerX1 = this.centerX1;
Robot.visionSubsystem.centerX2 = this.centerX2;
// double TargetMidpoint = (centerX2 - centerX1) / 2;
// double disp = (TargetMidpoint - Robot.vision.IMG_WIDTH / 2);
@SuppressWarnings("static-access")
double Turn = centerX1 - (Robot.visionSubsystem.IMG_WIDTH / 2);
//+ centerX2 - (Robot.visionSubsystem.IMG_WIDTH / 2);
// double Turn = (centerX2 - centerX1) / 2 - Robot.vision.IMG_WIDTH / 2;
Robot.chassisSubsystem.getRobotDrive().arcadeDrive (-0.6, Turn * 0.005);
// Make this return true when this Command no longer needs to run execute()
public boolean isFinished() {
if(centerX1 == 237.0 + 10){
return isCenter = true;
else if(centerX1 == 237.0 - 10){
else{
return isCenter == false;
// Called once after isFinished returns true
protected void end() {
// Called when another command which requires one or more of the same
// subsystems is scheduled to run
protected void interrupted() {
Unread 08-02-2017, 19:33
MuskieProgramme MuskieProgramme is offline
FRC #6420
Rookie Year: 2014
MuskieProgramme is an unknown quantity at this point
Re: Detecting countours
Because you only return true if centerX1 is 247 or 227, not anything in between.
You might go about using the values in between something like this:
Code:
return Math.abs( centerX1 - 237 ) < 10;
What this does is
1) finds the difference between 237 and centerX1
2) gets the absolute value of that
3) compares it to 10. Increasing or decreasing 10 will result in a larger or smaller error margin.
Unread 08-02-2017, 19:49
SamCarlberg's Avatar
SamCarlberg SamCarlberg is online now
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
To add on to MuskieProgramme,
Originally Posted by verlander13 View Post
Code:
		else{
This doesn't do what you think it does
WPILib
GRIP, RobotBuilder
Unread Yesterday, 08:37
FRC #6420
Rookie Year: 2014
Actually, it does exactly what he thinks it does. It makes isCenter true and then returns true.
http://stackoverflow.com/a/38163971
The assignment operator in Java returns the assigned value (like it does, e.g., in c).
Unread Yesterday, 14:00
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
Rookie Year: 2012
dvanvoorst is an unknown quantity at this point
The problem that people are trying to point out is that your CenterX1 will have to be EXACTLY that value for it to return true. It's not easy to move the robot to the exact pixel position you want, or at least it's typically not necessary to be that exact.
What MuskieProgramme correctly suggests is to give it an acceptable margin of error. In his example code, it will return true if CenterX1 is within 10 pixels of 237. Your acceptable error may be different.
