Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
Unread 08-02-2017, 21:21
Helium_1s2 Helium_1s2 is offline
AKA: Tommy
FRC #3322 (Eagle Imperium)
Team Role: CAD
Rookie Year: 2013
Helium_1s2 is an unknown quantity at this point
pic: Team 3322 Climb
Unread 08-02-2017, 21:22
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: pic: Team 3322 Climb
Congrats! I think this is one of the first systems I've seen demoed that actually has a solution for triggering the touchpad despite the steel channel that's flush with the bottom. How long did the climb take?
Unread 08-02-2017, 21:43
snekiam snekiam is offline
Rookie Year: 2010
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
Climbing is really quick for us - once we have the rope, its probably under 5 seconds, and getting the rope takes a similar amount of time. Total climb time is usually under 10 seconds.
Unread 08-02-2017, 21:45
AKA: Tommy
Team Role: CAD
Rookie Year: 2013
Thanks!
The climb is pretty quick. The time from grabbing the rope to reaching the touchpad is no more than a couple seconds.
Unread 09-02-2017, 19:40
Valkonn's Avatar
Valkonn Valkonn is offline
AKA: Paulo Garcia
FRC #3495 (Mindcraft Robotics)
Team Role: Mechanical
Rookie Year: 2014
Valkonn is an unknown quantity at this point
Originally Posted by Helium_1s2 View Post
Thanks!
What motor and reduction are you running?
Copy the best, screw up the rest.
Unread 09-02-2017, 20:08
[REDACTED] [REDACTED] is offline
FRC #2491
[REDACTED] is an unknown quantity at this point
That's a pretty neat field element there in the background. Care to tell me more about it?
Unread 09-02-2017, 21:19
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
2 CIMs in a 14.88:1 toughbox. "A couple seconds" is a bit optimistic. We've ever explicitly measured it, but from videos we've taken, the whole process will certainly be under the 10 seconds we have allotted for it.
Homebrew airship with a lift and a davit that can handle a climbing robot. I'll see if one of the folks who built it can put together some information about it. It is quite neat!
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 09-02-2017, 22:44
JohnD JohnD is offline
Rookie Year: 2015
JohnD has a spectacular aura aboutJohnD has a spectacular aura aboutJohnD has a spectacular aura about
The airship was built with about 10 2x4x8' boards and a few other miscellaneous pieces of wood that we had on hand. We have 200 lbs of weight on the back about 6' away from the rope to counterbalance the robot while it climbs; you can see two tie-down straps in the back that connect the weights to the airship. The straps and 1/2" bolts with wingnuts holding the 'six' sides together let us quickly disassemble the airship when needed (if you look closely you'll see we've only built 3 sides so far).
The touchpad is a Pacman-ish 10" circle cut out of 3/4" plywood with a notch around the channel. We used 3/8" bolts to mount it to the arm (each is about 6" long). There are weak springs around the 3 bolts to give us about 1" of travel to emulate triggering the touchpad.
Each GE-17075 divider has velcro on the bottom and is bolted to a vertical plastic plate that wedges between the airship sides. That way for early testing they can flex out of the way of the robot.
There is a working gear lift behind the legs of my teammate in the hooded sweatshirt. We've busted two of the GE-17064 peg points already that were made with a plastic similar to the material called out. I wonder if these are going to need to change to a more pliable material.
Unread 09-02-2017, 23:03
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
Rookie Year: 2011
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
This could be a red flag of your design because you could get called for G15-H.
How did you break them?
#StaySavage
Unread Yesterday, 00:32
Rookie Year: 2010
They came off when we were placing gears on the lift.
Unread Yesterday, 00:39
Basel A's Avatar
AKA: @BaselThe2nd
Honestly, if they're representative of the ones on the field, the ones on the field are gonna break all the time. We didn't put any unusual forces on there.
-Paul Copioli
