For Valentine's Day, I will spoiler with a spring bouquet.
Unread 08-02-2017, 23:00
pmattin5459's Avatar
pmattin5459 pmattin5459 is offline
AKA: Patrick Mattin
FRC #5459 (Ipswich TIGERS)
Rookie Year: 2015
pmattin5459 will become famous soon enoughpmattin5459 will become famous soon enough
Passive vs Active Gearing
I've seen a lot of passive boxes around on cd. Are there any advantages to an active mechanism for gear placing? The way I see it, it's a very small time gain for a lot of effort, but there may be other advantages.
Unread 08-02-2017, 23:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Passive vs Active Gearing
we are using an active mechanism, so the gear actually gets far enough on the peg to be lifted without falling off.
Unread 08-02-2017, 23:06
Classified*'s Avatar
Classified* Classified* is offline
Just grab a hacksaw and go.
AKA: Julia Cecchetti
FRC #0291 (CIA: Creativity in Action)
Team Role: Leadership
Rookie Year: 2015
Classified* will become famous soon enough
As an active gear team, I do not regret having the extra complexity one bit! With our mechanism we hardly need to stop at the peg instead of waiting for the pilot to pull it completely clear of the mechanism. It was a lot of work, but worth it.
Team291.com
Work smarter, not harder.
Unread 08-02-2017, 23:23
JR0405's Avatar
JR0405 JR0405 is offline
Electrical & Pneumatics/Mechanical
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
Rookie Year: 2011
JR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to allJR0405 is a name known to all
Active manipulators will save time every time but how much time they save really won't be determined till competition and it's all affected by the pilot and how aware they are of a robot being at the lift peg.
#StaySavage
Unread 08-02-2017, 23:29
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
The area that gears are placed is not a safe zone. A clever driver could probably hit a robot at the right time to knock a gear off the lift.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016) | FTC Referee (2017)
Academic Student (Forever)
Unread 09-02-2017, 07:49
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
We have an active gear placer, mostly to get the gear closer to the shaft collar end of the peg. If we have a team which is removing gears from pegs, we can remain in place to protect the gear, as the peg will be reaching into our frame perimeter, but will have "clear sky" overhead for a lift (We're pushing the gear on the left and right sides.)
Unread 09-02-2017, 09:56
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If they can see it.
There's also a good chance teams will attempt to strand defenders on the legs between the lifts .
2017 Scoring Model
CAD Library | GitHub
Unread 09-02-2017, 10:22
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
If the team's objective is to score 2-3 gears per match the time benefits don't compound all that much.
If the team's objective is to score 4-6 gears per match the time benefits compound twice as much! Suddenly a few seconds per cycle add up to the time needed to climb, score some fuel, or perform a defensive play.
Advantages I see:
-Robustness in placing gear/maximized misalignment capability
-Speed in placing gear (1-10s per gear, depending on what else the pilots are doing)
-No need to coordinate with pilot
-Improved auto reliability and/or ability to do more than a gear in auto without relying on a pilot
-Potential to be part of a 3-gear auto
-Some mechanism and packaging advantages (it is really helpful to not need a slot for the peg going through part of the robot)
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 09-02-2017, 10:36
JesseK's Avatar
FRC #1885 (ILITE)
The tricky thing about this comparison is that on the surface, a few extra gears isn't worth much (see attachment).
Yet the average difference in alliance score can be (2 to 3 per match for 3rd bot) a 55% chance of getting the 4th rotor vs (4 to 6 for 3rd bot) a 97% chance of getting the 4th rotor. That is massive.
Probabilistic models were created at www.getguestimate.com. I added a link to my signature.
2017 Scoring Model
Unread 09-02-2017, 11:05
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Passive or active, there is always the curse of drive station 2.
Unread 09-02-2017, 11:09
JesseK's Avatar
FRC #1885 (ILITE)
What curse is that?
2017 Scoring Model
Unread 09-02-2017, 11:23
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Originally Posted by JesseK View Post
What curse is that?
Sight lines. They are going to be terrible.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 09-02-2017, 11:36
T8PineappleSam T8PineappleSam is offline
Jonathan
AKA: Jonathan Zwiebel
FRC #0008 (Paly Robotics)
Team Role: Driver
Rookie Year: 2013
T8PineappleSam will become famous soon enoughT8PineappleSam will become famous soon enough
I'm going to agree with the statement that the tradeoffs in creating an active mechanism does not seem like it will be worth the small amount of time saved except maybe at the extreme high performance level.
The main issue with a passive mechanism that seems to be mentioned is time for the pilot to notice and pull the gear. While this may add an additional half to full second in the time the pilot takes to physically pull up the lift, I think that the expectation that the pilots will be too busy to see or be able to respond to the passive gearing robot is overstated. Pilots will be focused on the match. Pilots will pull up the gears from incoming robots before placing and turning the ones on the ship. And of course pilots can tend to the passive gear bots before pulling up the gears from the active robots. The only situation I can see where a reasonable pilot would not be at the lift the moment the passive gear bot gets there is if three passive gearing robots all get to the airship at the same time.
That being said, I can see an active mechanism having a benefit if it is easier to integrate into the design or more space efficient. Personally I feel that the time to design and the additional point of failure that results from an active mechanism is just not worth the few seconds you will save each match.
Jonathan Zwiebel
Driver, Project Manager, Programmer [Team 8, Paly Robotics]
2016 Central Valley Regional Finalist and Wildcard, Silicon Valley Regional Quarterfinalist, Curie Division, CalGames Quarterfinalist and Entrepreneurship Award, Capital City Classic Quarterfinalist
2015 Central Valley Regional Entrepreneurship Award, Silicon Valley Regional Entrepreneurship Award, Capital City Classic Semifinalist and Judges' Award
2014 Central Valley Regional, Silicon Valley Regional, Chezy Champs
Unread 09-02-2017, 14:22
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Actually I believe that the main issue with passive systems is that there are only 2 pilots, which means that 1/3 of the time your pilot will not be in the airship, meaning that a pilot whom is NOT experienced with your robot will be lifting the gear out of your passive system and will not be aware of the nuances of your system
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
  #15   Spotlight this post!
Unread 09-02-2017, 14:42
CalTran's Avatar
MST Rolla Senior
Rookie Year: 2010
If your passive system takes more than just a straight pull to get the gear out of the robot, you should probably re-evaluate your system.
