Go to Post If you base a team on how well you do on the field you have a much harder time winning. - Bob Steele [more]
Unread 09-02-2017, 00:11
KFARRAR2100 KFARRAR2100 is offline
FRC #0456
KFARRAR2100 is an unknown quantity at this point
Question regarding Network Cameras
Due to the commonly used Axis Network Camera(M1013, etc.) being out of production I was wondering if any of the other Axis Network Cameras will work with the FRC dashboard, and if not, what Company or Network Cameras also work with the FRC Dashboard?
Unread 09-02-2017, 11:00
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Re: Question regarding Network Cameras
If all you want to do is display the video feed on the Driver Station, then any IP Camera should work.
When we first used the Axis Camera years ago, we couldn't get it to work with the FRC software. However, we could open a browser window and directly connect to the camera to get the feed.
I highly recommend giving the camera a fixed IP address of 10.TE.AM.11. That makes it easy for you and the software to find it.
Unread Yesterday, 09:00
The FRC libraries are written to the VAPIX API, a proprietary HTTP based library from Axis. It provides rich configuration support. Other IP cameras can certainly work, but many of them don't allow for updates to the full set of imaging parameters. And they will have a different commands. If you choose to use another IP camera, you can open a connection using a web browser, and you can describe that URL using Network Tables so that the default and Smart dashboards will work as well. The brightness and other settings will likely not work, however.
All Axis cameras I've tested since the 206 use the same API, though some of the subset it a bit.
Greg McKaskle
