Trouble installing pynetworktables on jetson
My team is using a Jetson TX1 for CV this year, and I am getting to the part where I need to communicate. Network tables seemed like an easy solution, but I'm having problems installing pynetworktables.
I followed the instructions here http://robotpy.readthedocs.io/en/lat...ynetworktables for the linux install, but after the pip install (using sudo -H), I can't import the library in my CV code. Tne problem seems to be having mismatched python versions, as my CV is configured for 2.7, but the networktables only installs for 3.5, even if I am using regular pip instead of pip3. Is there any way of getting it working for python 2.7, or should I start looking at serial? |
Re: Trouble installing pynetworktables on jetson
Worked perfectly! Thank you so much!
