Go to Post There was no real separation between who did what. "we" did it all and it was fun. - Team2339 [more]
Unread 09-02-2017, 14:45
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond reputeHitchhiker 42 has a reputation beyond repute
Teleop Pausing Itself
As the title explains, when I enable tele-op, tele-op pauses itself. This hadn't been a problem before this and no change was made to the code between then and now. Is there an explanation for this and how do I fix it?
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 09-02-2017, 15:18
Jonathan L. Jonathan L. is offline
Programmer alumnus, mentor, and CSA
FRC #1094 (Channel Cats)
Rookie Year: 2011
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
Re: Teleop Pausing Itself
What exactly do you mean by pausing? Do the Driver Station Comm and Code LEDs stay green when TeleOp "pauses"? Are you running the code permanently or with the run arrow?
Unread 09-02-2017, 16:18
Roboter
Rookie Year: 2015
I have comms and code still. I am running the code with the run arrow. By "pause" I mean the built-in LabVIEW pause button is activating itself.
Unread 09-02-2017, 16:36
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Do you have a breakpoint in your code that you added by accident?
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
Unread 09-02-2017, 16:42
Roboter
Rookie Year: 2015
No. I did forget to mention that I had e-stopped the robot sometime around/before then. Could that have an effect?
I did cycle power and restart the code, driver station, etc. after that, though.
Unread 09-02-2017, 16:43
BrennanB's Avatar
AKA: Brennan Bibic
Estopping should be fine if you have rebooted everything. Are you getting any errors on the driver station?
Unread 09-02-2017, 17:05
Roboter
Rookie Year: 2015
Yes - lots. However, all of the ones I'm getting are related to having things in code that don't physically exist yet, and are the same as before.
I do want to note that I pulled the same version from github and ran that and it worked fine.
Unread 09-02-2017, 17:18
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Open Robot Main and go to View->Breakpoint Manager and see what's listed there.
There might be two default breaks, but there shouldn't be any more.
Unread Yesterday, 14:21
Unexas Unexas is offline
Lead Programmer
AKA: Douglas Byrd
FRC #3753 (BulahBots)
Rookie Year: 2011
Unexas is just really niceUnexas is just really niceUnexas is just really niceUnexas is just really niceUnexas is just really nice
You shouldn't be running the program by the arrow build it then deploy it and run it from the driver station.
Unread Yesterday, 14:24
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
He's probably just debugging the program, as an actual build/run as startup takes several minutes.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread Yesterday, 14:27
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
This is not true. LabVIEW is meant to be able to run without a full deploy. If you have a slow laptop or packet loss, that can cause the behavior you are seeing. In addition, any errors showing in the diagnostic window can potentially cause issues.
Unread Yesterday, 15:03
Rookie Year: 2011
A slow wifi connection to the programming computer should not cause the robot to do anything out of the ordinary but it may cause indicators on the computer to be delayed. A slow wifi connection to the DS could cause some hiccups, however.
Are you seeing the pause button near the run arrow turn red? If so, what happens when you click the red pause button to un-pause?
Unread Yesterday, 15:04
Just to pile on, ... err ... , I mean clarify, LabVIEW debugging involves running the VI interactively by pressing the run button
Each VI's compiled code is downloaded to memory, connections are established so that you can see panels, probe, breakpoint, change some values on panels, etc.
Once the code is working well, you build an exe and deploy it. There happens to be a way to compile debugging into an exe, but that is not used as often as the interactive case.
Greg McKaskle
Unread Yesterday, 15:07
Rookie Year: 2011
Does deploying as startup produce the same pausing behavior?
  #15   Spotlight this post!
Unread Yesterday, 15:50
Roboter
Rookie Year: 2015
Yes, the pause button turns red. When I un-pause it, it finishes that iteration of the teleop loop, and pauses on the next iteration.
