Go to Post Could you explain this concept of a break from FIRST? Did my wife put you up to this? - Gary Dillard [more]
Unread 09-02-2017, 18:33
SquirrelBoy's Avatar
SquirrelBoy SquirrelBoy is offline
AKA: Andrew K.
FRC #4004 (M.A.R.S. Rovers)
Rookie Year: 2016
SquirrelBoy is an unknown quantity at this point
Post How do I find speed of the ADIS16448 IMU using LabView?
We are trying to use the ADIS16448 IMU to calculate out speed/distance to use in autonomous mode in LabView, but we can't find anything on the topic. If you have any information in using this device with LabView, please let us know. Thanks.
Unread 09-02-2017, 20:06
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: How do I find speed of the ADIS16448 IMU using LabView?
Do you know calculus?
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread 09-02-2017, 20:09
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Generally using an IMU to calculate displacement is a bad idea. IMU's use accelerometers. To get position, you need to double-integrate the acceleration term, and that leads to large amounts of noise.
To determine you location on the field, use the gyro / yaw function of the IMU to accurate use direction, and use drivetrain encoders to monitor distance.
