Go to Post Weren't you ever told Canada is backwards from the US? - Alex Cormier [more]
Unread Yesterday, 16:36
Unexas Unexas is offline
Lead Programmer
AKA: Douglas Byrd
FRC #3753 (BulahBots)
Rookie Year: 2011
Unexas is just really niceUnexas is just really niceUnexas is just really niceUnexas is just really niceUnexas is just really nice
Code Won't Deploy
Hi, I am trying to deploy code to the robot and i build then deploy but, it still says i need to build it. Every Single Time. I have gotten it to deploy once but it said on the driver station that it had no code.
Is there a different firmware for the roborio if you run java instead of labview?
We were going to use java but the guy who was doing it was put on academic probation. I only know labview.
Any help would be great!
Unread Yesterday, 20:16
flemdogmillion's Avatar
flemdogmillion flemdogmillion is offline
Programmer, Builder, Driver...
FRC #3007
Rookie Year: 2015
flemdogmillion will become famous soon enoughflemdogmillion will become famous soon enough
Re: Code Won't Deploy
What you have to do is not build then deploy, but rather build then run as startup.
Team 4506: 2015-2016
Team 3007: 2017
Jack of all trades except C++ & Java
Unread Yesterday, 20:57
And to answer your other question, the same firmware supports LabVIEW, Java, and C++.
Also, does your code run correctly using the run button?
Greg McKaskle
