Go to Post The numbers that I gave were purely theoretical and should not be considered realistic - Karibou [more]
Unread Yesterday, 20:27
caljames caljames is offline
FRC #5914
caljames is an unknown quantity at this point
Unable to get Atonomus to run
Getting an error code of "Watch dog not Feed"? Any idea what that means?
We cannot find anything on it.
Thanks
Unread Today, 04:40
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Re: Unable to get Atonomus to run
It is a safety thing. It makes sure your code has not crashed.
At the beginning or end of each autonomus.periodic and teleop.periodic, you feed the watchdog.
GetWatchdog.Feed();
Or you can disable it.
getWatchdog.setEnabled(false);
If you are already doing that, make sure you have the most recent:
1) Roborio Firmware
2) Driver Station version
3) radio firmware
sometimes a connection problem can cause it.
Unread Today, 06:51
FRC #5914
Thank you!! We will try your suggestions and let you know.
Unread Today, 10:51
FRC #5914
Good Morning Rich,
Our robot will work in tele-op, but will not work Autonomous.
We tried each of your suggestions, but Eclipse does not recognizes what Watchdog is?
Thanks,
Unread Today, 11:02
IamCshort IamCshort is offline
FRC #5713 (Cyber Bucs)
Team Role: Team Spirit / Cheering
Rookie Year: 2016
IamCshort is an unknown quantity at this point
Send a message via AIM to IamCshort
Try the the "setSafetyEnabled" using the robot drive "chassis.setSafetyEnabled(false)" return false so the safety is off. Sorry if I could not help. Also ( make sure you dont use the name chassis it was just an example use the name of your RobotDrive you created)
Unread Today, 11:40
FRC #5914
Thank you both for all the help, but we managed to fix our problem by changing autonomousPeriodic to autonomous in our code due to recent changes that we were not informed of.
Have a good build and tournaments
