Go to Post FIRST, in itself, will not make you an engineer. - RogerR [more]
Unread Yesterday, 23:42
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to behold
Exclamation Navx in a Command-based Java program
We're able to get the navx sensor to work fine in an iterative program, but we're having trouble getting it to work in a command based program.
It compiles, but we're getting the famous "Robots don't quit" message with an error: -1029. We tried creating the object in the drivetrain subsystem, in robot.java, and in robotmap, to no avail.
Any help would be appreciated! Here's our code
Thanks!!
Unread Today, 00:42
wj2k3 wj2k3 is offline
FRC #2337
wj2k3 is an unknown quantity at this point
Re: Navx in a Command-based Java program
try:
public static AHRS ahrs = new AHRS(SerialPort.Port.kMXP);
instead of:
static AHRS ahrs = new AHRS(SPI.Port.kMXP);
and add import:
import edu.wpi.first.wpilibj.SerialPort;
Unread Today, 09:52
droswell's Avatar
FRC #2370 (iBots)
Thanks! We'll give it a shot this morning.
