Go to Post the few, the proud, the animators. - BuddyB309 [more]
Unread Yesterday, 02:11
Skammerman0 Skammerman0 is offline
FRC #5199
Skammerman0 is an unknown quantity at this point
Setting Servo Values
Hello all,
Our team is using an Actuonix L16 servo and we are trying to program it to extend to set values. I am able to fully extend it and extend it half-way, but I cannot make it fully retract. Here is my code:
Code:
Joystick XBACKS = new Joystick(0);
double servoBoy = 0.0;
Servo servoDude = new Servo(0);
while (isOperatorControl() && isEnabled()) {
                        if(XBACKS.getRawButton(3)){
			servoBoy = 0.0;
			servoDude.set(servoBoy);
			if(XBACKS.getRawButton(4)){
				servoBoy =  .5;
			if(XBACKS.getRawButton(5)){
				servoBoy = 1.0;
The code is a bit abbreviated but all the ideas are there.
If anyone could tell me what I'm doing wrong, then that would be really helpful. Thank you!
Unread Yesterday, 09:48
MuskieProgramme MuskieProgramme is offline
FRC #6420
Rookie Year: 2014
MuskieProgramme is an unknown quantity at this point
Re: Setting Servo Values
I'm on an FTC team which regularly uses servos. Last year, when they introduced the new control system we noticed our servos would not hit their extents (full left/full right). It turns out, the default was set to drive ModernRobotics servos, not HiTechnic, and they use different pulse widths.
So I'd try changing the minimum pulse width the Servo class is sending out.
