My motors are hot for you!
Unread 11-02-2017, 13:18
NolanGZ3452's Avatar
NolanGZ3452 NolanGZ3452 is offline
FRC #3452 (GreengineerZ)
Team Role: Driver
Rookie Year: 2013
NolanGZ3452 is an unknown quantity at this point
Retaining Rings Sticking Outisde of Frame
My team had a question about the frame perimeter rules, we have a few roller shafts sticking outside our frame perimeter about a 10th of an inch with a retaining ring and was wondering if this is legal.
According to the rules:
R01. The ROBOT (excluding BUMPERS) must have a FRAME PERIMETER, contained within the
BUMPER ZONE, that is comprised of fixed, non-articulated structural elements of the ROBOT.
Minor protrusions no greater than ¼ in. (~6.3 mm) such as bolt heads, fastener ends, weld
beads, and rivets are not considered part of the FRAME PERIMETER.
TL;DR are retaining clips considered a fasteners?
Thanks!
Unread 11-02-2017, 13:22
Mechvet Mechvet is offline
Electromechanicad Mentor
AKA: Craig Hickman
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Re: Retaining Rings Sticking Outisde of Frame
The purpose of a retaining ring is to keep a shaft from leaving a designate location, therefore one could easily argue that it FASTENS the shaft in place.
Unread 11-02-2017, 15:58
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
I would probably see it as a minor protrusion if I were inspecting you. Would probably need to see it in person to be more sure.
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 11-02-2017, 16:59
Robo Hamsters Robo Hamsters is offline
AKA: Matthew Vesperman
FRC #4466 (Robo Hamsters)
Rookie Year: 2012
Robo Hamsters is on a distinguished road
Yes, a retaining ring is a fastener, but, they are placed in a groove on a shaft, or pressed onto a shaft. Either way the shaft extends past the fastener and as such would be beyond the frame perimeter itself. The portion beyond the fastener is still the shaft and not part of the fastener.
To be absolutely sure though, you should ask in the official q&a.
FRC 4466
FTC 7042
2013 Washington DC Regional Finalist
Unread 11-02-2017, 17:17
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Nolan,
An inspector would have to see to make a ruling but in my experience, a clip on a shaft is usually pushing against a bearing. Most such assemblies will end up being more than 0.10" beyond the frame. In any case, the end of the shaft is the protrusion.
Al
WB9UVJ
www.wildstang.org
________________________
