MSC and FIRST/Banner Sensors
A fun e-mail blast from FIRST today. . .
MSC carries the gamut from sprockets to raw material to full-blown HVAC equipment and it seems like if it were all available to teams in unlimited quantities, that level-playing field notion would start to slip away. Still, they are a much larger supplier than SPI, and hopefully a lot of the problems teams have encountered in the past will not happen again. Also of note, the sensors are being sent to us early. Not much earlier, of course, but that does seems a bit interesting, seeing as they were included in last year's kit with everything else. What could this indicate? It may mean that FIRST is giving teams; rookies, particularly, an opportunity to familiarize themselves with the how the sensors work (with the EduRobot, possibly) before kick-off. That means, of course, that they could play an integral role in this year's game, which could lend itself to the possibility of some level of automation. Ack! |
I like the variety MSC has and suspect that we will be limited to certain pages or a certain budget for materials.
The only problem is that for those of us in the West there are only two offices, both of which are about a 10 hour drive from LA. That means that unlike many teams in the East, we MUST use their shipping department. Hopefully it will be better organized than SPI's. If I request overnight shipment, it had better be here before I can drive to Reno and back. Assuming I make their deadline for same day ship of course. On the other hand, if I'm that desperate maybe there are other problems too. Personally I would have prefered Mcmaster-Carr, but this isn't too bad. If they're as big as McMaster then they won't have any problems handling our piddly little orders. The enhanced sensor capabilities are good news too. I think I'll go borrow the Procurement guy's Banner catalog and go drool a bit. Then I'll go figure out how to get them working on EDUbot. |
Re: MSC and FIRST/Banner Sensors
This is big news. I have an MSC book on my desk and it is HUGE! It is about the size of the SPI catolog x 20 (big book with really thin pages).
This is exciting. Quote:
Sure, if we can buy anything we want out of this book (which I doubt), the bigger teams will be able to bug more stuff than the teams with less money. However, now both of these teams at least have the opportunity to buy the part, where before the bigger team used other resources (mainly engineering and fabrication expertise) to create the part they needed. For example... I see that MSC sells SMC-brand pneumatic grippers. Pneumatic grippers are pretty expensive ($200+). In the past, if a team wanted a gripper, then they had to design it. Now they can buy one (a limited design, but it is there). The team with more resources would end up designing and fabricating one while a team without the resources would just do without. I'm not sure... but this change may actually even the playing field more. We shall see... I really don't know right now. Andy B. |
Re: Re: MSC and FIRST/Banner Sensors
I can also see the return of the dreaded BOM and spending limits in the offing. That will complicate the equation more. Do I buy it almost ready made and go over budget, or do I spend precious time and resources to make it? Just one more engineering judgement to make. Fun isn't it? |
WHOA! VS.NET???? Really? That's awesome.
MSC is a great source!
I agree with Andy. Greater availability of stock parts can level the field. In the past, there were teams that were making their own gears. Personally, I like being able to order them.
You are never going to completely level the field when you are competing with the big teams with the big budgets and the excellent resources. I think it is more important that the teams with the small budgets and the limited expertise can get the parts required to create a mobile base. And things like sprockets, gears, keyed shaft, and other items make that more obtainable. A level field is like a wheel that rolls without slipping, a frictionless surface, and many of those other assumptions we learned to automatically write down at the begining of every dynamics problem... |
Re: MSC is a great source!
But, what falls within the 'stock parts' category? Sprockets, gears, chain, raw materials, etc. . . what about that HVAC stuff? Hydraulic components? Pneumatics components? Air motors? AC Motors? Surely, there needs to be some limit. Having access to MSC's ability to stock more items is definitely a major improvement over SPI, but the amount of stuff available is almost overwhelming. My concern would be in, say, buying additional motors. A financially solvent team could buy tons of motors for use on their robot. A money-strapped team could not, and could not likely manufacture them out of raw materials. So, is that still a level playing field? Of course, I realize that there's likely a limit on motor and pneumatics usage. I'm just curious as to how far the limits will go. |
I also agree with Andy B that allowing anything to be purchased will level the playing field. But I also think that limiting the budget that teams can spend in the catalog will offset that leveling effect.
Please don't take this as bragging - it is just a fact that my team (111) can make quite a few things out of raw materials. We have all the equipment and plenty of expertise to design many things very quickly. Trust me, the only thing that limits WildStang is the weight restriction. We can design around any cost restriction and get a huge advantage over inexperienced teams. |
#10
Hmm. An interesting point.
But what if there were pricing restrictions that put a limit on the total you could spend - and that total was a combination of purchased parts and "cost of production" of parts made from raw materials (which could be calculated by the amount of time required to produce, multiplied by some pre-defined $xx dollars/hour figure for machinist's time). If that were done, then the advantages enjoyed by teams with full machine shops would be reduced to a more level playing field (and it would probably drive certain very-well equipped teams nuts! ).But on the other hand, do we really care all that much if some teams have more production capability or access to more machinists or more mentors or more students than other teams? Do we really need to go to extraordinary lengths to level the playing field completely and make the competition "totally fair?" One of the (many) purposes of FIRST is to expose students to some of the real-world practices to professional engineering. In the real world, companies virtually always have certain capabilities that are not shared by their competitors, which they exploit to their advantage. Why should this competition be any different? (as Momma Lavery always told me when I was a young 'un, "no one ever said that life was fair.") -dave --------------------------- Y = AX^2 + BX + C |
#11
Raul's idea
Then he goes and post that he agrees with me... ha! It was his idea in the first place, and he didn't even say anything! This goes to show how much of a class act Raul is. Definitely a gracious guy who many of us admire. Andy B. |
#12
Why do you think they're giving us VS.NET? To make dashboard programs or server scripts for our webpages? I find it hard to explain...
). i mean, it's all lovely and such that we're getting VS.NET, but I would really like to know why... |
#14
Since I'm one of the only ones on my team that knows any of the languages in VS.net (C/C++, VB, etc) I'm hoping there isn't going to be anything about the game that requires it as I would have to teach high-power languages to the rest of the team in addition to PBASIC. On the other hand, if there's some kind of new programming award, I would be very happy... Last edited by rbayer : 21-12-2002 at 16:08. |
#15
Yes, in the real world thats called advertising. Heres a free sample, if you like it buy more and products like it. Its how marketing departments work. Kinda like autodesk with inventor ![]() |
