Go to Post Safety glasses may be a nice forehead protector, but thats not what they are made for. - Quatitos [more]
Unread Yesterday, 18:40
Kyle Davis Kyle Davis is offline
FRC #5242
Kyle Davis is an unknown quantity at this point
SmartDashboard output help
Hi, I am having an error whenever I run certain code on the roborio.
When i commented out all of the code in method driveForward() except the variable declarations, the console doesn't output any errors, but when I uncomment and include leftEncoder.reset() and rightEncoder.reset(), I get an error that disables my robot. Any help is appreciated.
This is the code I am running:
package org.usfirst.frc.team5242.robot;
import edu.wpi.first.wpilibj.AnalogInput;
import edu.wpi.first.wpilibj.BuiltInAccelerometer;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.interfaces.Accelerometer;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboar d;
* This is a sample program to demonstrate the use of a soft potentiometer and
* proportional control to reach and maintain position setpoints on an elevator
* mechanism. A joystick button is used to switch elevator setpoints.
* WARNING: While it may look like a good choice to use for your code if you're
* inexperienced, don't. Unless you know what you are doing, complex code will
* be much more difficult under this system. Use IterativeRobot or Command-Based
* instead if you're new.
public class Robot extends SampleRobot {
//Drive Objects
BuiltInAccelerometer accel;
RobotDrive drive;
Joystick stick;
Encoder leftEncoder;
Encoder rightEncoder;
Accelerometer accelerometer;
final int kPotChannel = 1; // analog input pin
final int kMotorChannel = 7; // PWM channel
final int kJoystickChannel = 0; // usb number in DriverStation
final int kButtonNumber = 4; // joystick button
final double kSetPoints[] = { 1.0, 2.6, 4.3 }; // bottom, middle, and top
// elevator setpoints
final double kP = 1.0; // proportional speed constant
double motorSpeed;
double currentPosition; // sensor voltage reading corresponding to current
// elevator position
// make objects for the potentiometer, elevator motor controller, and
// joystick
AnalogInput potentiometer = new AnalogInput(kPotChannel);
Victor elevatorMotor = new Victor(kMotorChannel);
Joystick joystick = new Joystick(kJoystickChannel);
public Robot() {
public void driveForward2(float distance, float speed)
public void driveForward(float distance, float speed)
int pulsesPerRev = 1024;
double inchesPerRev = 6.0 * 3.141;
double currentSpeed;
double currentDistance;
double acceleration;
double deceleration;
double driveDelay;
currentSpeed = 0.0;
currentDistance = 0.0;
acceleration = 0.01;
deceleration = 0.02;
driveDelay = 0.01;
//rightEncoder.reset();
//leftEncoder.reset();
rightEncoder.setDistancePerPulse(inchesPerRev / pulsesPerRev);
/*while(currentDistance < distance)
SmartDashboard.putNumber("Distance", currentDistance);
if (currentSpeed < speed)
currentSpeed = currentSpeed + acceleration;
//drive.tankDrive(currentSpeed, currentSpeed);
drive.tankDrive(0, 0);
Timer.delay(driveDelay);
currentDistance = (rightEncoder.getDistance() + leftEncoder.getDistance()) / 2;
while (currentSpeed > 0)
currentSpeed = currentSpeed - deceleration;
if (currentSpeed < 0.0)
currentSpeed = 0.0;
* Runs during autonomous.
@Override
public void autonomous() {
//drive.setSafetyEnabled(false);
SmartDashboard.putNumber("start go", 1);
driveForward((float) 24.0,(float) 5.0);
SmartDashboard.putNumber("stop", 5);
//drive.setSafetyEnabled(true);
* Moves elevator to a selectable setpoint that can be changed by pressing a
* button on the joystick. Proportional control is used to reach and
* maintain the desired setpoint by obtaining values from the potentiometer
* and comparing them to the setpoint value.
@Override
public void operatorControl() {
boolean buttonState;
boolean prevButtonState = false;
int index = 0; // setpoint array index
double currentSetpoint; // holds desired setpoint
currentSetpoint = kSetPoints[0]; // set to first setpoint
while (isOperatorControl() && isEnabled()) {
buttonState = joystick.getRawButton(kButtonNumber); // check if
// button is
// pressed
// if button has been pressed and released once
if (buttonState && !prevButtonState) {
index = (index + 1) % kSetPoints.length; // increment set point,
// reset if at end
// of
// array
currentSetpoint = kSetPoints[index]; // set setpoint
prevButtonState = buttonState; // record previous button state
currentPosition = potentiometer.getAverageVoltage(); // get position
// value
motorSpeed = (currentPosition - currentSetpoint) * kP; // convert
// position
// error
// to
// speed
elevatorMotor.set(motorSpeed); // drive elevator motor
* Runs during test mode
@Override
public void test() {
Unread Yesterday, 19:13
forbes's Avatar
forbes forbes is offline
Software developer
AKA: Evan Forbes
FRC #3507 (Ubotics), 694 (StuyPulse)
Rookie Year: 2012
forbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to behold
Re: SmartDashboard output help
Do you ever initialize the encoder objects?
For example:
leftEncoder = new Encoder(0, 1, false, Encoder.EncodingType.k4X);
http://first.wpi.edu/FRC/roborio/rel...j/Encoder.html
Also for future reference, it would be helpful to post the entire error you get in addition to your code
