| We go together like a Drill motor, reduced by 3.6:1, and a CIM motor. |
Configuring Old Radio as Switch/Hub
Is it possible to configure old Radio (The one in KoP of 2014) as a switch or hub to be able to use more ports on robot. I want to use axis camera and raspberry pi, but there are not enough ports available.
Re: Configuring Old Radio as Switch/Hub
For the old Dlinks, you will have to:
1) Disable the wifi 2) Disable the DHCP server At that point, it should work fine as a hub/switch. Link to the manual in case you need to learn how to reset the router and configure it: http://www.dlink.com/-/media/Consume...l_v1_EN_UK.pdf |
