My motors are hot for you!
Unread Yesterday, 18:02
Valkonn's Avatar
Valkonn Valkonn is offline
AKA: Paulo Garcia
FRC #3495 (Mindcraft Robotics)
Team Role: Mechanical
Rookie Year: 2014
Valkonn has a spectacular aura aboutValkonn has a spectacular aura aboutValkonn has a spectacular aura about
Post Gap Between BUMPER and FRAME PERIMETER Legality Question
I was going through the checklist and found that our bot was in violation of R31 (my bad ) but was unsure of a legal solution.
The specific part we are in violation of is:
"Additionally, any gap
between the backing material and the frame:
A. must not be greater than ¼ in. (~6 mm) deep, or
B. not more than 8 in. (~20 cm) wide"
So it's greater than 8 inches, which means we have to move our support pieces inwards. The distance from the support to either end of the robot is fine, it is only the middle that is too wide.
However, knowhere in the rules did I see a statement on how much the bumpers need to be supported by the frame. In particular, would the following solution be legal?
As you can see, the minimum distance is now less than 8 inches, but the maximum distance:
is still over 8 inches. Would this solution be legal during inspection or does the "minimum" distance have to be <8in?
Copy the best, screw up the rest.
Unread Yesterday, 18:14
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Gap Between BUMPER and FRAME PERIMETER Legality Question
Maybe it's just the way the drawing looks to me. But are your wheels OUTSIDE your frame?
If so you've got a far bigger problem, because now your wheels form your FRAME PERIMETER, and the BUMPERS have to be attached to them.
If that's not the case, and your wheels are set back inside, then you may not need to change anything. You don't need a BUMPER along the whole side of your ROBOT. You only need at least 6 inches from each corner. If you're willing to leave the center wheel exposed, you don't need to have a BUMPER there at all.
(since 2004)
Unread Yesterday, 18:20
Valkonn's Avatar
AKA: Paulo Garcia
Rookie Year: 2014
The wheels are recessed by a bit. I also would like to have the center wheel protected rather than exposed.
Unread Yesterday, 18:21
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Your solution appears to be legal. You your only allowed 8 in gap without no support. The rules don't detail how robust the support needs to be. But keep in mind that defense is likely to be rigorous.
If you don't know what you should hook up then you should read a data sheet
Unread Yesterday, 18:23
Chris is me's Avatar
AKA: Pinecone
This has been something literally hundreds of robots have done every season since 2010, and is completely legal. This is probably the most common style of drivetrain in FRC apart from the kitbot. Having cantilevered wheels does NOT require your bumpers be attached directly to the wheels. The rectangle tubing members on either side of the wheels are intended to be the frame support. They stick out farther than the wheels do.
OP: The sideways configuration you showed is totally fine. Basically the bumpers have to touch a frame member every 8 inches. It doesn't matter how MUCH of the frame they are touching - they can touch just a 1" tall section like the sideways tubes show. It's no problem. As long as the "gap" between each tube is less than 8 inches it's fine.
--2016 Waterbury SFs (with 3314, 3719), RIDE #2 Seed / Winners (with 1058, 6153), Carver QFs (with 503, 359, 4607)
-- 2015 TVR Motorola Quality, FLR GM Industrial Design -- 2014 FLR Motorola Quality / SFs (with 341, 4930)
-- 2013 BAE Motorola Quality, WPI Regional #1 Seed / Delphi Excellence in Engineering / Finalists (with 20, 3182)
-- 2012 BAE Imagery / Finalists (with 1519, 885), CT Xerox Creativity / SFs (with 2168, 118)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
Unread Yesterday, 18:26
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
I couldn't tell from the side-on view whether the wheels were the closest thing to me or not. Thus my concern. It would be far easier to fix it now than when they showed up for inspections.
(since 2004)
Unread Yesterday, 18:37
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
Team Role: Coach
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
  1. Congrats on reading the rules multiple times with a critical eye on your own team's work.
  2. Thank you for providing the best set of drawings to explain your problem and solution idea that I think I've ever seen on CD.
  3. You are correct about both the problem and the legality of the solution. Well done!
  4. Can I rep this post ten times? I wish all questions could be handled the way you handled yours.
http://www.angelbotics.com
Remember why you're doing this.
Unread Yesterday, 20:25
Cash4587's Avatar
Cash4587 Cash4587 is offline
Mentor
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Team Role: Coach
Rookie Year: 2013
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
You could always just rivet a small piece of aluminum plate onto the 2x1 in the upright position to make it have more bumper contact. It would fulfill the rule. I have seen teams that even just run some 36" long tube axle spacer from vexpro down the entire length of their frame above their wheels to fulfill the rule as well.
Unread Yesterday, 22:53
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
IMHO, it is silly that you have to have backing where you don't have to have a bumper.
Unread Yesterday, 22:58
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
It is silly to bring a baby buggy to a demolition derby.
Richard Wallace
since 2003
Unread Today, 00:25
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
True. Nominated for spotlight.
Unread Yesterday, 18:16
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Can you attach a plate that extends to the left and right of the post? Most "west coast drive" chassis have some sort of post with a plate.
Also, you technically don't need bumper in the middle. Just 6" on each side of a corner of the frame perimeter.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
DopeCADSwag DopeCADSwag is offline
FRC #1360
DopeCADSwag is an unknown quantity at this point
Thank you for posting this, I decided to check our bot just incase, and it turns out we broke this rule too... :/
