Go to Post It will mean far more than you can imagine...and really, you can't lose. - David Kelso [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 08-01-2002, 01:42
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
Exclamation Can we use Maya?
A member of our team specializes in Maya, and has access to some small company’s lab where he can work. Is it a good idea to use non-AutoDesk software in the animation for 3D work? I guess he could adapt to 3DS if he needs to, but it would be better if he could use what he was familiar with...
Do you think it's acceptable?
Unread 08-01-2002, 02:00
Unsung FIRST Hero
Nate Smith Nate Smith is offline
FRC Key Volunteer Trainer
AKA: CrazyNate
Rookie Year: 1998
Nate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to behold
Send a message via AIM to Nate Smith Send a message via Yahoo to Nate Smith
As I've mentioned on a few other threads regarding using other software on the animation, the description of the judging criteria for the animation award specifically says "3dsmax and other Autodesk software"...you're going to want to get an official OK from FIRST/Autodesk before using any non-Autodesk software.
Nate Smith
nsmith@smythsoft.com
12 seasons, 4 teams, and more time logged behind the scorekeeper's table than I care to remember...
returning for 2011? only time will tell...
Unread 08-01-2002, 02:27
Ah. Thanks. I sould have searched...
Unread 08-01-2002, 07:19
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
The Autodesk people last year didn't have a problem with people using some othe programs for their work (IE, modeling the robots in Rhino because it handles booleans without the face loss bug) as long as the majority of the work and the final renderings were done in MAX. I don't know if the same rule applies, but you should be able to do the key modeling in MaYa if you can find a way to export to MAX.. unless 4.2 will import binary files, come to think of it. Anybody had luck hopping between MAX and MaYa so far?
Unread 08-01-2002, 14:44
Zeinin Zeinin is offline
#0449 (Blair Robot Project)
Zeinin is an unknown quantity at this point
Send a message via AIM to Zeinin Send a message via Yahoo to Zeinin
we are doing good with max and lightwave together, using Rhino as a go between
if you have a file, rhino should convert it.
1.4 gzh athlon TBIRD
512mbs ddr
GeForce 3
SBLIVE 5.1
Anyone using other tools? djcapelis 3D Animation and Competition 43 21-11-2003 15:50
A Tale of Ten Thousand Crashes Nero 3D Animation and Competition 19 16-03-2003 22:21
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Free Alias|Wavefront Maya! Trashed20 3D Animation and Competition 13 24-06-2002 17:52
**** TEAM 64-A's ANIMATION SUBMISSION **** Sunny Thaper 3D Animation and Competition 7 04-05-2002 23:25
