Large Multiplication..
Ok.. I've come upon a weird problem that probably doesn't come up very often.. and as I'm not good at math at all (and yet a program.. lol) I just can't figure it out. Here's the problem:
I have a 64-bit number (8 bytes.. so wasteful of memory am I) which I need to multiply by a 8 bit number. Obviously this is a problem as the PBASIC language doesn't support many mathematical functions.. and the stuff it does support is limited to 16 bits I think.. Anyway, any assistance that someone could give would be helpful! |
First, multiplying an 8-bit number and a 64-bit number could give you a 72-bit number if I remember my binary correctly (or maybe it's 71?). Anyway, it's going to be bigger than your original size. Well, my binary's a little rusty, as is my math thanks to winter break, but I'll give this a shot. Assuming your 64-bit number is broken up into 8 byte-sized variables named bigVar1-bigVar8 with 1 being the highest-order byte and 8 being the lowest, and assuming smallVar is your 8-bit number, the formula would look something like this:
result0 var byte result1 var byte ... result8 var byte temp var word temp=bigVar8 * smallVar result8= temp & $00FF temp=temp & $FF00 >> 8 + (bigVar7 * smallVar) result7=temp & $00FF temp=temp & $FF00 >> 8 + (bigVar6 * smallVar) result6=temp & $00FF temp=temp & $FF00 >> 8 + (bigVar5 * smallVar) result5=temp & $00FF ... temp=temp & $FF00 >> 8 + (bigVar1 * smallVar) result1=temp & $00FF result0=temp & $FF00 >> 8 Don't quote me on any of that as I haven't tested it yet nor do I even know how I would. Anyway, result1-result8 now have the product and result0 has whatever overflow may have occurred. Anybody want to verify this algorithm/shoot it down? As I said, it may or may not work. Finally, I have to ask: what possible purpose could you have for a 64-bit number in PBASIC? |
add it all up
To multiply two large numbers you can add the 8-byte value to itself multiple times in a loop. You will need to reserve an extra byte for the results. This is probably painfully slow, I do not endorse this at all.
Here is a basic algorithm, I'm not sure whether it will work. I don't see a reason for needing this, but here is a crack at it anyways. Code:
'inputs for the sub that will add the numbers together bigVar VAR BYTE 'pointer to the low-order byte in RAM resultVar VAR BYTE 'pointer to the results in RAM smallVar VAR BYTE '8-bit operand numBytes VAR BYTE 'number of bytes in bigVar 'working variables op1 VAR BYTE op2 VAR BYTE temp VAR WORD position VAR BYTE counter VAR BYTE '64-bit operand starts at ram location 1 'this represents the value $0807060504030201 PUT 1, $01 PUT 2, $02 PUT 3, $03 PUT 4, $04 PUT 5, $05 PUT 6, $06 PUT 7, $07 PUT 8, $08 'set up values for the call to the subrountine bigVar = 1 'pointer to RAM location for operand 1 resultVar = 10 'pointer to RAM location for results numBytes = 8 'number of bytes in operand 1 smallVar = 100 'multiply operand 1 by 100 GOSUB FindBigProduct 'now, the results are stored in RAM locations '10 - 18 (9 bytes total) '---------------------------------------------- 'subroutine to multiply a multi-byte value 'stored in RAM by a byte. The multi-byte value 'should be stored in sequential RAM locations 'in order from least to most significant byte '----------------------------------------------- FindBigProduct: 'initialize the results to 0. there 'will be numBytes + 1 bytes in result FOR counter = 0 TO numBytes PUT resultVar + counter, 0 NEXT 'exit if the other operand is 0 IF smallVar = 0 THEN FindBigProduct_Return 'loop through and add the value in 'bigVar to itself smallVar times. FOR counter = 1 TO smallVar 'reset the running sum so 'that it handles overflow temp = 0 'loop through and add each 'byte together, saving overflow FOR position = 1 TO numBytes 'get the operands GET bigVar + position - 1, op1 GET resultVar + position - 1, op2 'add them together temp = temp + op1 + op2 'save the low-order byte PUT resultVar + position - 1, temp.byte0 'shift the overflow temp = (temp & $FF00) >> 8 NEXT NEXT 'save the highest order byte PUT resultVar + numBytes, temp.byte0 FindBigProduct_Return: RETURN Last edited by seanwitte : 30-12-2002 at 17:08. |
First, thanks for the assistance..
Second, as to why you need something this large.. two reasons why I posted: a) another person didn't think it could be done and I did (just didn't know how to do it) b) for use in a really high-res counter loop related to speed regulation.. we were brainstorming stupid ideas and this happened to come up as part of one of those.. Anyway, thank you much for your assistance! |
integers are only 4 bytes
I don't remember for sure, but most languages I've used allocate 4 bytes for a long integer. Thats a range of -2,147,483,648 to 2,147,483,647 for a signed int or 0 - 4,294,967,295 for an unsigned int. You wanted to use an 8-byte number, which is a float data type that has an signed length of about 28 digits.
<EDITED> Thanks, I was thinking of the IFI controller fixed processor loop, even got it wrong. The stamp runs at 20MHz, 4000 instructions per second. To increment a number from 0 to 4,000,000,000 would take at least: (1 second/4000 instructions) * 4,000,000,000 instructions = 1,000,000 seconds = 17,000 minutes = 283 hours = 12 days </EDITED> Last edited by seanwitte : 31-12-2002 at 08:47. |
The Stamp runs considerably faster than 40 Hz. What you're thinking of is the fact that input data is sent to the Stamp at 20 Hz (I think it's 20 Hz; did I misplace my mind again?). If I remember correctly, the Stamp executes 1000 lines of code every second. It is possible to sit in a loop and execute it for a given period of time. However, you need to remember that if you miss 4 input packets (ie you don't poll for the input data), the Stamp controller will be reset by the master controller. So don't sit in the loop for more than .2 seconds.
Matt |
Re: integers are only 4 bytes
Also, just for the record, the Stamp is 50Mhz and does about 10,000 instructions/second. Don't forget that we have the BS2SX, not a BS2. Look here for a good comparison of all the different Stamps. However, as Matt said, the IFI controllers are quite a bit slower than this. Since the Stamp has no serial buffers, it has to actually wait while sending/receiving any data (Serin/Serout). |
Hardware option
Here's a HARDWARE solution for LONG (multi-second) times that's VERY repeatable: Create a simple one shot timer with a 555, and put it in the Electronics Box. Trigger it with a digital output, and read the status back with a switch input. If you wish a VERY precise time interval, you can make the timer out of a PIC micro, a "long range timer chip" (such as an EXAR XR-2242), or a crystal oscillator brick driving a counter/divider chain and some simple "done" gate logic. However, since the rules state you may ONLY drive functional robot devices with the RC outputs ("active decorations" are the only exception), in reality you're still limited to the time resolution of One Loop in any case. Therefore, a 555 timer will probably be just as good as something more elaborate. That circuit should only cost a couple of bucks to make. Don't forget that they MAY stop then continue a round for many reasons, so you should NEVER assume "powerup = start of two minute round"! A multi-minute timer (software OR hardware) to automatically trigger your 'near end of round surprise' may never time out if they stop the round, so you'll also need a driver manual trigger. - Keith |
| # of people on team how small or large | rcubes85 | General Forum | 5 | 18-02-2003 01:35 |
| The Universe is Large | Chubtoad | Chit-Chat | 25 | 12-08-2002 15:15 |
| Sensor use on Papst Large Fan | archiver | 2001 | 6 | 23-06-2002 23:14 |
| Size Is Large | archiver | 2000 | 15 | 23-06-2002 22:47 |
| Limited Vs. Large funds? | Mikeman602 | General Forum | 15 | 22-03-2002 08:15 |
