Go to Post Of course, every team in FTC should be asking the magic question: "What would Simbotics do?" - Billfred [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
  #16   Spotlight this post!
Unread 20-01-2003, 17:50
HFWang's Avatar
HFWang HFWang is offline
AKA: DarkWulf
#0115
Team Role: Webmaster
HFWang will become famous soon enough
Send a message via ICQ to HFWang Send a message via AIM to HFWang
i'd be shocked if anyone made a fully w3c compliant site.
too many people have a "good enough" approach to code.
  #17   Spotlight this post!
Unread 20-01-2003, 20:24
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Yeah, W3C compliant is like a blank page with words. Anything above that takes time to get done in spec.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
  #18   Spotlight this post!
Unread 21-01-2003, 22:34
HFWang's Avatar
AKA: DarkWulf
#0115
I actually tend to disagree.
Getting things done to spec should be something that is considered in the initial planning. For instance, making a massively complex table layout will probably not conform to spec because you didn't write in the little summary attributes in the beginning. Thus, it becomes a pain to get everything together. On the other hand, keeping in mind w3c specs early on, and working with them instead of around them... that works.
  #19   Spotlight this post!
Unread 22-01-2003, 02:21
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
Rookie Year: 2000
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
W3C standards were not necessarily created so that every web artist would go by the standards. Rather platform standards are only a guides that a programmers can use. W3C standards are good though they are slow in coming hand to hand with todays progressing Browser technology. Also if you use version 4 browsers , there is no need to bring that up as a valid argument.
Well just if you are wondering if you really need to make you team site going by the W3C standards, i would say there is no need to. Though if you really care about following the standards, Go ahead, because your will certainly not attract more visitors just by puting a W3C logo on your site.
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
  #20   Spotlight this post!
Unread 22-01-2003, 20:14
HFWang's Avatar
AKA: DarkWulf
#0115
Of course you don't attract more visitors by putting a w3c button on your site.
Neither does flash, or even prettier layouts. People come because they want the information contained therein. Does the end user care how the code is made? Does anyone really care that you used an industrial-strength Oracle DB to make sure everything runs fine and dandy? Not really.
The point of conforming to w3c standards is not for the sake of conformance. The issue is that by doing so you are pushing toward a more uniform web (IE: my site should display the same in IE as it does in Netscape, or Opera, or Insert Name of Browser Here). Just because a browser puts up with your bad coding doesn't mean that it should.
The reason W3C standards are not exactly hand in hand with current browser technology is that the browsers are not supporting standards. There are some crazy CSS properties that do everything but make coffee in the morning, but aren't supported by IE/Netscape. Those features are actually useful. (min-width/max-width anyone? Or how about columns without resorting to tables?)
Simple website questionnaire jonathan lall Website Design/Showcase 28 30-07-2003 23:42
No website?!?! Duke 13370 Website Design/Showcase 5 07-04-2003 13:24
Why isn't the FIRST website the place to get up to the minute regional information? Don Knight General Forum 7 12-03-2003 02:42
PLEASE Enter your robot and website Jeremy_Mc Scouting 1 28-02-2003 15:27
Update 7 - Behind Schedule (or out of questions)? archiver 2000 2 23-06-2002 22:58
