OCCRA
Go to Post I'm not worried about the amount of Segways at a regoinal, I'd rather see them out in the real world than at a robotics competition. - Joe Matt [more]
CD-Media
Unread 03-22-2017, 07:37 AM
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Making a Triple Helix style climbing rope
During the quarter-finals of our last competition our Pilot looked out over the field and noted that 3 of the teams of the field were using our climbing ropes, one of which was on the opposing alliance. After seeing so many posts about ropes failing in competition, 2363 has decided to share our method for making ropes with the FRC community.
Materials:
Solid braided rope from West Marine, 5/8" diameter.
3mm Spectra Speargun line
Plain backed loop side velcro
Upholstery thread
tape
Tools:
Scissors
long, pointy stick
sewing machine
Instructions:
Watch the instructional video we put together last night.
The length of the spectra rope will be specific to each team's robot and climber. We use three knots in our rope: the figure 8 knot in the spectra, that keeps the core from pulling through the big knot; the big figure 8 knot, that rests on the davit fingers; and a slip knot just above the velcro patches, that allows a couple wraps around the climber shaft before starting to climb. Each of these knots consumes a surprising amount of rope length. You can figure out how much for yourselves, experimentally. If you are using some other type of loop knot at the bottom of your rope, be sure to use a version that's suitable for spectra rope. Spectra is very slippery, and knots that work with other types of rope will pull out of spectra rope. As noted in the video, the only failure of our rope was one match where the spectra rope pulled through the big figure 8 knot. After that we added the stopper knot to the spectra above the big knot.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 03-22-2017, 09:28 AM
mypie4050's Avatar
mypie4050 mypie4050 is offline
AKA: Micah Young
FRC #4050 (Biohazard)
Rookie Year: 2013
mypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nicemypie4050 is just really nice
Re: Making a Triple Helix style climbing rope
Looks like you guys got it figured out. Luckily, we've avoided any issues with our rope failing; our robot has a semi-active rope catching mechanism, you can see it in action in detail here: https://youtu.be/MA3WYanS0Q8?t=31s and in-match here: https://www.facebook.com/Biohazard40...3280017079884/
Micah Young, Mechanical Engineering Major at Geneva College
FRC 4050: Member (2013-2017); Mentor (2018+)
Unread 03-22-2017, 02:44 PM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
I was unsure about whipping partway down the rope, but the Q&A does say that any cut end can be whipped, so good there.
I think the only improvement would be if you could thread the spectra through the core as well instead of beside the core through the cover. Then you'd have that much more material the davit would have to bite through to get your load carrying line.
Unread 03-22-2017, 02:48 PM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Interesting. This is only the 2nd of its kind that I've seen (the first being ours). I like the simplicity of the 1x1 + bow tie cone.
1885: YouTube | CAD Library
Unread 03-22-2017, 04:35 PM
henryBsick henryBsick is offline
Fuel is not important ;)
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Todd,
125 used a similar rope construction with a different method in last weekend's Greater Boston district event (MABOS)
This rope from McMaster is ~1/8" spectra core with protective braided jacket (~1/4" OD)
  • 36965T15
We tied our knot up top (bowline), cut to length per robot hang drum height, then measured down ~1' from the knot and remove all braided jacket below, to be left with something similar to your additive construction.
To finish, we frayed the bottom ~3-6" of exposed 1/8" Spectra to engage with our velcro hanging drum (no velcro on rope required!)
It worked great for us and we'll continue this method going forward; however, we'll probably be using a fresh rope for each new competition to be overly safe.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 03-23-2017, 07:57 AM
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Rookie Year: 2011
Originally Posted by henryBsick View Post
Todd,
125 used a similar rope construction with a different method in last weekend's Greater Boston district event.
Very interesting. Got any photos? Interested in seeing how you attach up top.
I wonder why there is such a dramatic difference in load ratings of the rope. I'd expect yours to be WAY stronger than ours. (Wait. Just saw the 5:1 safety factor. It IS way stronger.)
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 03-23-2017, 07:58 PM
Rookie Year: 1998
Given there's a bowline at the top, they're doing a lark's head knot over the davit fingers. Perfectly legal as long as the two standing lines of the loop pass over the top of the knot so there's no way it could slip over the pin.
Unread 03-24-2017, 04:06 PM
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Very cool!
In much the same way you 'cored' bigger ropes with the spectra line, we 'cored' our rope with a bit of elastic. This serves the same function as a slip knot, but no one has to remember to tie it to the proper length every match. I'm not sure if this can be integrated into the spectra rope easily (perhaps elastically retract the spectra inside the 'sheathing' rope?), but it might be worth considering to eliminate the reliance on human preparation/skill to get a climb.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 04-09-2017, 02:46 PM
cpapplefamily's Avatar
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to beholdcpapplefamily is a splendid one to behold
All the taped "wipped with tape" was tagged illegal at our regional and had to be removed. Cited as adhesive.
Unread 04-09-2017, 03:23 PM
AriMB's Avatar
AriMB AriMB is offline
The Philadelphian emigrant
AKA: Ari Meles-Braverman
FRC #5987 (Galaxia)
Rookie Year: 2012
AriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond reputeAriMB has a reputation beyond repute
Originally Posted by 2017 Game Manual
I04D. consist entirely of (except for dye or adhesive applied by the VENDOR as part of the normal manufacturing process for a COTS item and no longer tacky, e.g. a “binder coat”) flexible, non-metallic fibers sewn, twisted, tied, woven, knitted, crocheted, intertwined, or braided together except for the last 4 in. (~10 cm) of any cut end (E) which may be whipped (with material that is flexible and non-metallic) or fused only to prevent fraying.
Emphasis mine
This is the way I read it: The whipping material in the last 4 inches is exempted from the requirement to be entirely "flexible, non-metallic fibers". Instead, it must be "flexible and non-metallic". Therefore there is no rule that the whipping material must be fibrous. Adhesive tape, though it is an adhesive non-fibrous material, is generally both flexible and non-metallic. There is no rule outright allowing adhesive materials on the rope. I don't see why this would have been ruled illegal. Maybe someone who was there or the LRI who made the ruling can explain otherwise.
Studying MechE at the Technion - Israel Institute of Technology
2017-present: FIRST Israel CSA/FTAA
2017-present: FRC 5987 Technical Mentor 18isr2 18isr4 18isrcmp 18carv
2012-2016: FRC 423 Member 15njtab 15padre 16paphi
Unread 04-09-2017, 03:51 PM
Rookie Year: 2015
We didn't buck the ruling as it didn't end our day. Our rope was some material that when heated -melted. Removed the tape and moved on.
Unread 04-09-2017, 06:08 PM
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
This thread completely slipped my mind with the grind of competitions, better late than never I guess?
Please forgive the zip-tie that was constraining yet-to-be handled frayed outer casing ends.
Ended up using this rope through 3 competitions. We'll have a new one for worlds.
//can't imgur don't care to figure it out.
http://imgur.com/hZjdBCh
Mechanical Engineer
Digital Lumens
NU ME: 2011
Powered by vBulletin®
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
