Go to Post Chief Delphi is special. ... Self-police please. - PayneTrain [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
Unread 08-01-2003, 13:22
Klondike Mike Klondike Mike is offline
#0174 (Arctic Warriors)
Klondike Mike is an unknown quantity at this point
Good Idea
[Here's how it works:
Depending on how many variations you need, you have some number of limit switches. One switch for two programs, two for four, and three for eight, etc.
Depending on what program you want to run, you place little blocks in front of the appropriate switches, so that they are always stuck in either the on or off position.
Alternatively, you could just have a small jumper block wired to the RC inputs to do the same thing. [/b][/quote]
Thank You - This is an excellent idea!
Winter is the season for Robotics
Unread 08-01-2003, 21:33
johnscans johnscans is offline
#1019 (team decepticon)
johnscans is an unknown quantity at this point
one of our head programmers is insane and i fear that he may try to make it all AI. i fear the outcome- may the big mna in the sky be wathcin over us.
john
team 1019
Unread 08-01-2003, 23:01
Jeff Jeff is offline
#0122 (NASA Knights)
Jeff will become famous soon enough
Enabling Autonomous Mode
Not sure if this has been answered somewhere else, but I've seen the question a few times now: How do you enable autonomous mode? Answers have included settin the team number to 0000, simply set your outputs to neutral, or just don't touch your controls.
As you get your robot running and really want to test out how it will perform in competition, being able to simulate the competition conditions will often reveal hidden problems that you did not anticipate. On the Innovation FIRST web site there is a single page document that shows you how to use the competition port to do three thinigs:
1.) Enable autonomous mode
2.) Enable alternate channel access
3.) Enable/diasble robot controller output (i.e. start/stop a match)
I've provided the URL below. I would encourage teams to make this adapter, and use the enable/disable switch as a safety when you are testing your robot or even just demonstrating it around guests. It is a good idea to always have a "safety officer" with this switch, ready to shut off the robot at any time with the push of a button. The motors and pneumatics you may be using can cause serious injury - keep safety in mond ALL the time.
This adapter is easy to make and you do not need to be fearful of "messing" with the compeittion port. Just BE CAREFUL because incorrect wiring CAN destroy your controller. Have your wiring and all the connector pins checked and double checked before you install it. Use shrink wrap around the solder connections to insulate the connections and prevent accedental short circuits.
Making and using this adapter will not only allow you to simulate actual competition situations, but will also help you operate and test your robot more safely.
Competition Port Instructions
Jeff
Unread 08-01-2003, 23:19
Norm M.'s Avatar
Norm M. Norm M. is offline
Norm M. will become famous soon enough
Sell me your Dongle!
Is it just me, or does it seem like it would make sense for IF to sell these already made up with a little PC board and a couple switches...
I hate soldering wires to those little solder cups, and then trying to stuff everything inside a backshell.
Now, of course, the lead time becomes an issue.
Unread 13-01-2003, 16:07
Quentinfool's Avatar
Quentinfool Quentinfool is offline
#0217 (Thunderchickens)
Quentinfool is an unknown quantity at this point
A few people on my team and myself have come to the conclusion that the game can be won or lost just as much in the first 15 seconds as in the last 15 seconds. i.e. someone uses autonomous mode to go to the center, pick up all the boxes and dump on their side. there's a hammond strategy if i ever heard one.
"A strange game. The only winning move is not to play"-War games
Unread 13-01-2003, 16:18
MacZealot MacZealot is offline
MacZealot is an unknown quantity at this point
Send a message via AIM to MacZealot
lol, yeah, anything can happen at any time. A good driver and a good auto script is a combination meant to kill
AIM: Joe7464685192 | Email Me! Visit my site!
Uh I'm STILL not in Las vegas GRRRR!! I dun think it'll happen till june and This shoulda happened a freaking year ago
Unread 13-01-2003, 17:15
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
and there at least two quick counter-tactics to use against any robot utilizing this approach.
# 1 - get to the top of the ramp faster than they do, and knock the containers to YOUR side of the ramp (i.e. make it a race!)
# 2 - at the start of the autonomous period, your robot goes under the bar and bumps them from behind, knocking them off the line and futzing with their line/path following capability.
No strategy is foolproof, and all of them can be countered if you are creative enough. The hard part will be choosing which one to use during any given game!
-dave
Unread 13-01-2003, 18:02
My idea goes like this:
Have the robot in it's start position where it's facing the pole, and have it go under (or over), and knock the opponent bot outta line.
Then you go into full reverse as far back as needed, and hit the ramp at high speed + knock down the stack onto your side
Unread 13-01-2003, 20:33
JLambert's Avatar
JLambert JLambert is offline
#0151 (Wild Cards)
JLambert is an unknown quantity at this point
Send a message via ICQ to JLambert Send a message via AIM to JLambert Send a message via Yahoo to JLambert
Originally posted by Cory
has anyone noticed how choppy those lego line readers are? Ive watched them, and I saw about three inch jumps from either side of the line. I dont know if this is an issue with our sensors as I know nothing about them. Did anyone think of placing multiple bins along the lip on the ramp. When robots started going towards the ramp in autonomous mode, more likely than not they would hit these, and they could get caught on the lip, making it impossibleto move by. If nothing else, I'd imagine this would really confuse the bot.
Cory
The Lego bots are jumpy because their sensors are so close together. If the sensors are placed a bit more apart, and it will be smoother. However, If they are placed too far apart, it could be a little TOO smooth.
Justin Lambert
02-03: Programmer Team #151
Unread 13-01-2003, 23:18
EvilInside's Avatar
EvilInside EvilInside is offline
Robots, Cars, Physics!
#0706 (APE)
EvilInside is an unknown quantity at this point
Send a message via AIM to EvilInside
Autonomity Period
I, in contrary belief to many of you, do NOT think that the game will be won or lost in the first 15 seconds. Considering line-following is easily disrupted, and dead-reckoning is evil, there is just a little too much of a chance something will NOT go as planned. Now, I'm more of an engineering student on Optimus Prime, but I have gone far enough into programming to know a bit about it. Different factors come into play when programming dead-reckoning, such as the charge of the battery, random obstacles, etc. When it comes to line-following, no matter how far apart your sensors are the turning will always be choppy, purely because of how the sensors work. Unlike last year's game, this game has no definate way of controlling it. Since we didn't go to Nats last year (the first year I was on the team) I didn't get to see anything outside our Regionals. Team 71 was able to control the game by grabbing all three goals, and that was it. Unfortunately, this year we can't just grab all the goals and walk into the scoring zone. There is always controlling the ramp, but there are several problems with that.
a) It leaves your alliance partner in a 2 on 1 scenario, which is never a good thing
b) You only score 25 points, with the other goal being to prevent the other team form getting up to 50 points, therefore limiting your own QP
c) Whether you are any use at all is dependant on the first 15 seconds where you have zero control over your 'bot, and therefore cannot react to dynamic situations
NTM several other problems. Of course, I know what I think the best way to go is, but I'm not sharing at least not now.
"All your bins are belong to us" "You can't teach God anything"
Unread 14-01-2003, 14:44
so you're saying that a robot CAN'T grab all the boxes and win?
hmm, very interesting. i wouldnt be suprised in 71 pulled something like that. never say u cant do something.
Unread 14-01-2003, 18:14
Jeremy L's Avatar
Jeremy L Jeremy L is offline
Videographer, Team 177
AKA: The Basket Maker!
None #0177 (Bobcat Robotics)
Jeremy L is on a distinguished road
Send a message via AIM to Jeremy L
Cool i srtongly disagree! (with something)
regardless of whether a game can or cannot be won in the autonomous mode, it only takes one robot, intentionally or otherwise, to knock into the middle and alter the tide for the remainder of the match. i personally believe that some games will be won by chance or luck, i.e. a robot that hasn't been following a line all of a sudden does, and then strategy will be messed up for that alliance. of course, there are ways of making sure that a robot can't even get onto the ramp, such as placing the human player bins right at the bottom. considering the lips both at the top and bottom of the ramp, i think that most robots would have a pretty difficult time getting all the way to the top to knock the stacks over (without damaging the human player bins severely !!)
it is therefore my belief that the game can be won in the human player mode. given the above situation as well as the general lack of very accurate dead-reckoning systems (in general) and the general lack of speed in line-tracker systems, i think that some very effective human player strategies are out there. i haven't thought about it that much, but i'm sure that there are very reasonable methods of preventing all robot types from being effective in the autonomous mode. for example, if a robot was designed to knock down human stacks, you could put a bin right in front of it and it would push it straight into the wall. for a loss of one bin, this is a good strategy that could save you some points later. ) this, of course, all depends on accurate scouting, which will be a big problem in this game considering the possibility of multiple autonomous modes.) well, there's my three cents worth...
Unread 14-01-2003, 20:04
Almost all depends on your programmers. Our team has a programmer that can program ANYTHING(so he claims). He sure as heck better.
Unread 20-01-2003, 21:34
yeah but not any robot can counter any strategy. every robot has its own limits but if no one has the ability to exploit these limits, thats how the strategy can be close enough to foolproof.
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
crazy idea for autonomous Mike Ciance Programming 16 24-04-2003 21:50
autonomous location manodrum Programming 4 02-04-2003 08:05
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
