Go to Post Ahhh... the beauty of an exponential series... - dtengineering [more]
Unread 04-01-2003, 16:43
Anne Lam's Avatar
Anne Lam Anne Lam is offline
FRC #0368 (Kika Mana)
Team Role: Leadership
Anne Lam is an unknown quantity at this point
Ramp BOM
Does anyone know where I can get a BOM for the ramp or on what page I can find it in the manual? Thanks!
Unread 04-01-2003, 21:14
AdamT's Avatar
AdamT AdamT is offline
#0401
Rookie Year: 2000
AdamT is on a distinguished road
http://www.usfirst.org/robotics/2003/docs.htm
If you can't find it there, it's not anywhere and it probably won't be. You're best option is to look at diagram and try and fudge it. I believe they announced that there were only 2 suppliers for the mesh.
Dave also gave some hints on alternatives for the mesh.
~Adam
Unread 04-01-2003, 22:08
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Rookie Year: 1998
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
hmmm
at novi, they said it would cost up to like 3-4 grand, and they were going to post cheaper suggestions on the first website. keep checking for updates
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 04-01-2003, 22:27
DanLevin247 DanLevin247 is offline
Missing In Action
#0247 ('da bears)
DanLevin247 is on a distinguished road
Send a message via AIM to DanLevin247
Re: hmmm
You mean "no ve"? I mean, that's what woodie called it!
'daaaaaaaaaaaaaa bears!
It's all fun and games till someone gets hurt.....then it's hillarious!
Unread 04-01-2003, 22:33
Stephen Kowski's Avatar
Stephen Kowski Stephen Kowski is offline
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
Stephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond reputeStephen Kowski has a reputation beyond repute
Send a message via AIM to Stephen Kowski
well the alternatives i believe were plywood....and as far as I can tell that isnt going to help you much to simulate anything.
Unread 05-01-2003, 00:31
Anne Lam's Avatar
Found it!....kinda
On page 2-3 of the game manual, there is a short description on what the ramp is made of, but nothing specific on the quantities. Page 17 has the specs on the wire mesh, white tape, carpet, retroreflective tape, container, HDPE and where to get all these things. That's about all the help that FIRST if going to give us to build the ramp, unless they post the BOM in the next update, hopefully.
Unread 05-01-2003, 10:49
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
The ramp is 18 feet across. 7'9" from the beginning of the ramp to the platform ON THE GROUND. the platform is 2 feet high. there are slight specs on the website.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 05-01-2003, 11:21
AdamT's Avatar
#0401
Rookie Year: 2000
For specifics on the demensions of the ramp, there is a nice CAD drawing od the field and it's compenents included in the rule book (similar to the ones they have released in previous years).
~Adam
Unread 05-01-2003, 11:43
Don Knight's Avatar
Don Knight Don Knight is offline
no team (Az Regional Planning Committee)
Rookie Year: 1998
Don Knight is just really niceDon Knight is just really niceDon Knight is just really niceDon Knight is just really niceDon Knight is just really nice
Cheaper Field Components
Better check those measurements again, remember measure twice cut once.
For the Phoenix Kit-off the metal portions of the field - Platforms and Ramps - were constructed out of wood. We used the proper quoted materials for the platform tops and grating material for the ramps and used plywood for the vertical sides of the ramps where FIRST had Lexan. Cost of material to build, not including labor was $1100.00.
Unread 05-01-2003, 12:05
Skanker's Avatar
Skanker Skanker is offline
#0498 (R.P.M)
Skanker is an unknown quantity at this point
Send a message via ICQ to Skanker
well, lets see---to build the ramp, say in plywood, you would need this much stuff:
Surface:
8 sheets 4 X 8 Plywood (probably 1 inch thick)
At roughly $16 a piece (I'm probably WAY off... haven't been to the hardware store) $128
Vertical Wood Struts (8 ft 2X40) to support the large ramp pieces- you'd probably need one every two feet... that would come out to 16 of them (gotta support the top of the bridge too).... they are like 6 bucks apiece... so $98
Horizontal wood struts (12 ft 2X4) you'd probably only need 6 of these... say, roughly $8 each--- $48
Posts to hold up the top--- you'd probably want 4X4, 2 ft long. say one every 4 ft on each side--- that's 8 of them. 16 ft. so two 8 ft 4X4's. say another $20.
THEN you need a couple huge boxes of screws (or nails, or bolts or whatever)... so add in $30.
add it all together, you can make just the ramp for---- roughly $324
that is probably an underestimate. and it's only the basic ramp-no polycarbonite sides, no field, no borders, no player stations.....
good luck building!
-Sean Rice
Cactus Robotics Club Alumni
Unread 05-01-2003, 12:59
BSEE, MSEE, JD
AKA: employed
Rookie Year: 2000
wow ok plywood won't give you an accurate idea of how your robot will drive on that wire mesh ramp.....maybe if you cut out 1" X 1" holes in everyone portion of it it might work, but I doubt then it could support much....this wire mesh and plywood are two entirely different surfaces with two entirely different textures...good luck :/
Unread 05-01-2003, 14:33
Anne Lam's Avatar
Surface:
good luck building!
This is exactly what I am looking for! Thank so much for your help!!
Unread 05-01-2003, 14:38
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
I wouldnt build a rampo without the wire mesh and HDPE. TO make it cheaper, you could easily build only 1 or 2 of the 4 sections of the ramp. Making it even cheaper, use a 1/4" sheet of HDPE backed by 1/4" plywood, and use plwood instead of lexan sides, along with wooden framing. I can't think of any way to make it cheaper without removing vital surfaces.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 05-01-2003, 15:10
Ron Hartman Ron Hartman is offline
#0079 (Navigators)
Ron Hartman is an unknown quantity at this point
Unhappy Need field CAD drawing
Does anybody have an electronic copy of the field CAD drawing included with the hardcopy rule book? Maybe it's on the CD??? We're waiting for our kits to arrive and the 'field layout' PDF file that FIRST posted just isn't enough to guide construction. We try to have the field hardware constructed in the first couple of days... if we have to wait for our kit to arrive, we're just that much further behind! Aargh!
Thanks for any help!
Ron
  #15   Spotlight this post!
Unread 05-01-2003, 20:11
rolocroz rolocroz is offline
Junior Member
#0852 (Athenian Robotics Collective)
rolocroz is an unknown quantity at this point
Send a message via AIM to rolocroz
At the San Jose remote kickoff, I saw some people looking at a blueprint of the field; I thought that that might be included in our kit. Apparently not -- but now I know that such a blueprint exists.
Q&A Discuss: How long is the bump from the ramp to the top? CD47-Bot Extra Discussion 1 11-01-2003 09:48
blocking the ramp Jacqui Sutton General Forum 3 07-01-2003 09:02
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
scoring ramp dimensions archiver 2000 3 24-06-2002 00:13
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
