Go to Post And just remember, it's an engineer's world. Without us, everyone is powerless, literally. - JoeXIII'007 [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 04-01-2003, 16:47
LBK Rules's Avatar
LBK Rules LBK Rules is offline
1467 '06 Alumni
AKA: Anthony Rinaldi
no team (HSRO)
LBK Rules will become famous soon enoughLBK Rules will become famous soon enough
Exclamation Explosions
How do you'll make animated explosions in 3DS Max?
Anthony Rinaldi
Team 1132: 2003
Team 1467: 2004 - 2006
Unread 04-01-2003, 17:40
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Look into particle effects. You can use Parrays to do object fragment particles. Look at the "Creating Explosions" tutorial that ships with Max 4 & Max 5.
Unread 05-01-2003, 11:08
Devil's Kid's Avatar
Devil's Kid Devil's Kid is offline
#0912 (IRON Lyons)
Devil's Kid is an unknown quantity at this point
For a smiple combustion or burning effect, create a sphere gizmo, then go to enviornment options, add a combustion modifier to it, and then play with some options.
Unread 05-01-2003, 11:38
Bduggan04's Avatar
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
You can also use stock video clips of explosions. This is show in the same tutorial.
Unread 06-01-2003, 07:37
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
awesome explosion all in one.
first create a particle array and explode that. then you must go to the g-buffer channel (right click the object and select properties) the default number is 0 ...you'll see it easyly. set that to any number but 0. let's say 4.
Also set some motion blur to it...I recommend an image motion blur set to 2.
then go and make a sphere gizmo and assign a rendering effect to that. Fire effect in the enviroment>render>main toolbar.
Make sure you sync the start and ending times to that of you particle array.
create a camera pointing at that explosion
now go to video post.
First step is to click on the teapot in video post and then click okay after you have selected you camera as the viewport. Then go to the add filter event. Click on video post glow. Click set up and then where it gives the opotions of what to filter by you'll see a 1 next to object (it has a check mark next it) or something like that. Change that one to a 4 and now you particles will glow.
if you click on the different tab menus you can modify your settings.
YOU MUST THEN CLICK OK or your setting won't save.
Final thing to add below the filter event is the output event. Select the file and the file location that you would like to save to and press execute.
You have now just created a sweet explosion.
any more questions or if I lost you somewheres let me know.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
