Go to Post Well I have to admit, most of the people on our team are geeks. I think that it's a title of honor considering it might as well be "boss" or "head supervisor" or something along those lines. - Cyberguy34000 [more]
Unread 04-01-2003, 17:38
riley_ag riley_ag is offline
#0824 (SWAT Robotics)
riley_ag is an unknown quantity at this point
Send a message via AIM to riley_ag
Arena Building: Cheap Materials
On the kickoff broadcast, they mentioned a list of cheap materials to possibly use on the arena. I am not finding that anyway, has anyone found this information?
2003 animation team leader, sub-team co-leader, and all the other stuff that I forget
Unread 04-01-2003, 18:32
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
It was my understanding at the Nov Kickoff that Woody was showing how the components of the field were in common sizes such as 4x8 for plywood on the ramps, you didn't need to add the polycarb ramp sides (or not use clear plastic maybe cheaper thin plywood) and the top platform could be plywood with a thin Laminate of the white plastic instead of the 1/2" thick piece used in their field.
After talking with the Killer BEEs who bought the field from Novi kickoff the cost of the parts to do it as shown is close to $3500.
I would strongly recommend that each team buy at least one 4x8 sheet of the mesh for a section of ramp to know what traction will be needed to traverse it.
Unread 05-01-2003, 23:13
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
More recommendations
A field was built in Kokomo also. After kickoff, I got the bill for the materials, and it was around $2,200.
The framework was built from 2"x6" boards. The top platform is made of HDPE. I strongly recommend that each team get a sample of HDPE plastic, since some types of rubber are slick on it and other types of rubber are not.
The sides of the field are supposed to be polycarbonate (1/2" thick). This material is not as important... it is just meant to be rigid and see thru. This polycarbonate costs about $1,200, so substituting it would save a good deal of money.
The wire mesh is also something that teams need to practice on. Sure, we all got a sample in the kit, but teams should buy large sections of this in order to test out driving on the stuff... this stuff is kinda slick also.
I suggest that teams build the entire ramp as specified, with a wooden frame, but without see-thru sides... then if you want to put a small piece of polycarbonate on the inside wall of the upper platform, then that would be a realistic ramp to practice on. This type of ramp would probably cost around $1-1,200.
Andy B.
Unread 06-01-2003, 13:46
Unsung FIRST Hero
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rookie Year: 1999
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
NYC R-Kickoff Ramp Structure BOM
FYI:
NYC Remote Kickoff (cheapest!) BOM of Ramp Structure:
$230 for 2 ramps and 1 platform.
Everything is from Home Depot minus the 2 wire mesh floor.
A single ramp
5 2x6x8 ft.
1 2x6x4 ft.
1 2x4x4 ft.
Single Ramp side panels
2 2x4x1/4 plywood
1 1x6x8 ft. (side rail)
A single platform Section
5 2x6x 5'9" (use end pieces for legs)
2 2x6x 4 ft.
4 2x6x 1'11.5" (see item 1)
2 2x4x 3'10.5"
2 1x4x 5'9"
Platform floor
3 2x4x1/4 plywood
Platform side panel
1 2x4x1/4 plywood
2 4x8 wire mesh ($50 each)
Unread 06-01-2003, 14:13
Unsung FIRST Hero
no team (NYC FIRST)
Rookie Year: 1999
North-East source for steel Mesh
FYI for North-East teams-
Source for Steel Mesh:
NcNichols Company
1-800-237-3820
Ask for Tom
New Brunswick, New Jersey
Cost for two sheets of sheet mesh: $107
You save $70 shipping if you pickup!
Q&A Discuss: Arena Building: Cheap Materials CD47-Bot Extra Discussion 1 22-01-2003 17:16
building materials, can we use....... archiver 2000 2 24-06-2002 00:11
Possible Configuration to keep things cheap archiver 1999 8 23-06-2002 23:03
Additional allowed materials kmcclary Off-Season Events 3 11-10-2001 13:05
