Would 18 stacked= 30 boxes if they were all in long position? and 15=27? |
I guess technically that would be possible...but c'mon, 20 some boxes stacked up end-to-end where they aren't tapered or anything. It would fall and crush your robot...well, if they put weights in them it would.
wrong, much more points
Though basically impossible, the maximum amount of points that you are able to score is 1,112
First, you have a stack or 22 and 23 others in your zone (or the other way around), giving you 506 points Then You must have both you and your alliances robot on top for 25 points each, 50 points total 50 + 506 = 556 Then as I read in the rules, if both members in the enemy alliance are Disqualified, then instead of doubling their total score, you instead double yours!!!!!!!!!!!!!!!!!!!!!! 506 x 2 = 1,112 I garuntee that nobody will get this amount due to not being able to stack 22 boxes, but it's still possible There's actually a way to get more, but I forgot how Any questions, ask me at I2ob36@hotmail.com OR IM me, my SN is I2ob36 Last edited by Rob36 : 08-01-2003 at 18:15. |
If there's one thing I've learned over the years it's... If you think it is imposible, some other team will do it. Anyways, while design I came up with a system to lift almost 30ft. It would certainly be pushing weight restraints... not to mention every other part rule known to first. I wanted to build it just to watch it fall over during a match... hehe a 30 ft, 80 lb arm falling across that lexan siding of the ramp... SMASH! That's if it didn't collapse under it's own weight in the first place. But somehow I know some team will figure it out...
remeber top qualifying score is one more point than other team not with one team getting blown out
| Fantasy Football! | EddieMcD | Chit-Chat | 176 | 30-12-2003 18:30 |
| 2004 Championship Eligibility Criteria!!! | dez250 | General Forum | 214 | 28-12-2003 20:11 |
| Chamionship Qualification - feedback needed ASAP! | dlavery | General Forum | 97 | 11-10-2003 07:17 |
| Seeding Calculations | archiver | 2000 | 50 | 23-06-2002 21:57 |
