And everyone knows the majority of the teams are gonna make the robot go up the ramp first, so it's a matter of speed and strength.
On a side note though, it'd be sweet if we could do flippin' this year, does anyone know why they banned it since they already said "This game is not ment to be fair."? |
Line Follower
Dead Reckoning...faster...so unreliable. I hope the materials are the same on the field as the ones you practice on.
I don't know, our team is going to have 2 bit switches for 4 automaton programs. The best way is to test it out, seeing if accuracy is more important to your team than speed. What if your alliance team member has a dead reckoning program too. Do you guys run into each other and slow each other down, while the other team comes over the bridge. Better yet, you hit, your now off target and going the wrong way. I'd say using the light sensors for the TURNING, then once your on the top use a yaw rate sensor to detect going up the ramp, to stop the light sensor turning. Right now based on our opponents/allies we're going to have One line follower, One dead reckoning, One seek and destroy, and One salvager or something |
Accuracy is a better power to have than speed, but it's true. It's gonna be like a demolition derby or something.
I believe an array of 5 sensors (probably not the normal optical ones, but "custom circuits") would make it very fast, if arrayed two on the outside, and three clustered together at the width of the tape between the other two. You can zip around and use the three for precise driving as much as possible, but if you lose the line at high speed, you've got the other set to follow the line more loosely. I haven't tested this yet, but I'm going to as soon as I get at last year's robot
That's why communication between teams is very important as well as multiple codes.
at least 3 (2 for automation (or however it's spelt), and 1 for the 2 min. part)
| pbasic 2.5 on 2002 competition year robot | yangotang | Programming | 4 | 10-02-2003 22:48 |
| Wow! what a year | archiver | 2000 | 8 | 23-06-2002 22:43 |
| Multiple Regionals | archiver | 1999 | 55 | 23-06-2002 22:26 |
| why why why...? | archiver | 2001 | 34 | 23-06-2002 22:13 |
| Making heads or tails of the new announcement... | Jessica Boucher | General Forum | 66 | 26-09-2001 11:13 |
