Go to Post My wife is in advertising, and uses a scary amount of math. They have to know how to target you and beat down your defenses, so that you buy that hamburger while driving that car while wearing those designer jeans to your favorite store. - Not2B [more]
  #16   Spotlight this post!
Unread 04-14-2017, 12:42 PM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Best HP Gear Cyclers in the World?
I'd encourage look at both styles - feeder & ground. In doing so, see which player station the team is in. There are inherent advantages & disadvantages for each style at each station.
For passive feed + active place, check out 384. They are crazy fast, and have a couple of ways to get even faster. Some of their moves on the field look choreographed & rehearsed. They hit 6 full-field cycles in many matches, though due to some early matches their average was about the same as ours.
For passive feed + passive place, check out 6334. They typically do the same basic lines, and are extremely good at it. Their average was identical to ours.
We (1885) have active ground feed and active place. We hit 6 full-field (+ auton) gears in 3 separate matches, and a usual 4-5 full-field gears under varying levels defense. We had a couple of low matches due to figuring out nuances of an upgraded intake. We only ground intake, but we also are willing to go around any airship at any time to get around defense.
Ground vs Feed - I don't think that debate is settled. A feeder can get in and out faster than a ground intake simply because the drivers can see every reference point on a more consistent basis. Yet feeders also have to deal with fuel, whereas most good ground intakes inherently deal with it by design. Feeders also have to figure out how to get to the same place every time, whereas there is a bit to be learned about match flow by how ground intake bots figure out where to go dynamically.
  #17   Spotlight this post!
Unread 04-14-2017, 01:04 PM
TheBoulderite TheBoulderite is offline
Will join FRC team for food.
AKA: Warren Bartlett
Rookie Year: 2015
TheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond reputeTheBoulderite has a reputation beyond repute
I'd argue 604. They are remarkably fast for an HP gear bot. Looking forward to having the chance to play with them next week on Hopper!
2015-2017: 1619 (Up-A-Creek Robotics)
2017-Now: None
My opinions and statements I make are my own and are not reflective of what any of my former teams believe or think.
  #18   Spotlight this post!
Unread 04-14-2017, 01:12 PM
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
From the NE perspective there are a few teams to add (in numerical order):
78 - Seeded second at NEDCMP with only gears, highest ranked team with no fuel capabilities. Ground-load only, comfortably 6-7/match with defense.
131 - Demonstrated the capacity for 7-8 gears/match with only HP loading
558 - 6-8+ gears/match and insanely fast ground-only pickup
5687 - Yet another team that can deliver 6-8 (maybe more?) gears with HP and ground capabilities. When we played with them at NEDCMP we got the mythical 5th rotor turning!
Edit: Whoops, didn't realize this was supposed to be HP ONLY robots. Still, only utilizing the HP+starting gear there are teams that can hit 8 gears total/match.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
  #19   Spotlight this post!
carpedav000's Avatar
carpedav000 carpedav000 is offline
FF: TSIMFD
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
Team Role: Mechanical
Rookie Year: 2010
carpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond reputecarpedav000 has a reputation beyond repute
Indiana had some really good HP cyclers that all looked to consistently score around 5 gears per match, such as 71, 234, 1018, 1741, 4272, and 6721
It isn't shiny enough.
  #20   Spotlight this post!
Unread 04-14-2017, 01:15 PM
Chi Meson's Avatar
Chi Meson Chi Meson is offline
Strange and Anti-Charmed
AKA: Brian Chidley
FRC #2168 (Aluminum Falcons)
Team Role: Teacher
Chi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud ofChi Meson has much to be proud of
Originally Posted by Caleb Sykes View Post
Top 25 teams by scored gear contribution:
Code:
team	Scored Gears Contribution
3238	6.52
3974	6.07
2590	5.41
6329	5.36
1937	5.35
78	5.34
5687	5.30
2168	5.20
203	5.17
230	5.16
340	5.07
1778	5.03
74	5.00
604	4.99
649	4.98
1684	4.91
3255	4.90
148	4.90
1676	4.85
2607	4.79
1720	4.78
836	4.73
384	4.67
751	4.67
68	4.64
This only looks at quals at each team's most recent event. It probably undervalues teams that had to consistently play through defense. Also, many of these teams have ground intakes.
2168 is ground intake only.
2017 New England District Champions
  #21   Spotlight this post!
Unread 04-14-2017, 01:23 PM
Unsung FIRST Hero
Karthik Karthik is offline
Rookie Year: 1998
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Another vote for 610. Their cycling ability is mesmerizing. 10-12 second cycles are a semi-regular occurrence for them.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
  #22   Spotlight this post!
Unread 04-14-2017, 01:27 PM
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
604 and 8 are tops in CA. Probably top 8 in the world at worst.
2001-2004: Team 100
2006-Present: Team 254
  #23   Spotlight this post!
Unread 04-14-2017, 02:13 PM
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
Team Role: Coach
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
The challenge for scout teams will be identifying great gear bots who happen to spend much of their time in quals shooting for the extra rp point...numbers don't always tell the whole story
"A genius is just a talented person who does his homework" T. Edison
  #24   Spotlight this post!
Unread 04-14-2017, 02:27 PM
cscottm cscottm is offline
Crazy Person
no team (Unoccupied)
Rookie Year: 2015
cscottm is just really nicecscottm is just really nicecscottm is just really nicecscottm is just really nicecscottm is just really nice
In MN, a big standout is 4536, the Minutebots. Their whole robot is gears and climbing and for a mecanum (vectored intake wheel) bot, they can run a solid 5-6 every match, climbing every time, even under defense.
  #25   Spotlight this post!
Unread 04-14-2017, 02:43 PM
mwmac's Avatar
mwmac mwmac is offline
JWBWIFW
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Agreed!
2017 Carver W 2122 987 4910 6314 IRI SF 1114 2122 1885 4028 ID W 5499, 2122, 3006, EEA WCan W 2122 4334 1482 EEA
2016 Carson W 2122 2052 3538 41 AZN W 2122 125 498 MQA ID F 2122 3250 3513 MQA CCC W 2122 9122 6174 ICA
2015 Tesla SF IDA 2122 3360 2960 1311 IRI SF 2338 2122 107 234 UT F 2122 3230 3405 EEA WFFA AZW W 2122 3309 5059 ICA
2014 Galileo QF 1717 2122 3683 193 UT W 2122 2996 3191 ICA CCC W 1678 2122 9073 ICA
2013 CalGames W 2122 1678 4171
2012 Newton QF 2122 610 488 Spokane W 2122 1983 4082 EEA
2011 Newton SF 1730 2122 11 IRI F 3138 16 2122 1730 UT W 2122 399 3239 MQA Seattle F 2122 488 2850 MQA
2010 Galileo SF 78 51 2122 UT W 1696 2122 3405 IDA SacTown F 2122 2035 1834 IDA
2009 SacTown F 2144 692 115 2122 MQA
2008 Newton SacTown W 2122 1662 115 CA
2007 PNW Regional HRS
Enjoying traveling to more distant events since 2007
  #26   Spotlight this post!
Unread 04-14-2017, 06:04 PM
jblay's Avatar
jblay jblay is online now
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
Team Role: Coach
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Also you need to take into account that some teams will stop scoring gears early cause they've reached 4 rotors or they know they are pretty much alone in gear scoring and stop after the 3rd rotor. Scouting this won't be easy at champs, and I think qualitative information will be very important.
It's pronounced StighPulse like HighPulse
2017 New York City Finalists
2017 South Florida Chairman's
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
  #27   Spotlight this post!
Unread 04-14-2017, 06:24 PM
Andrew Chauvin's Avatar
Andrew Chauvin Andrew Chauvin is offline
FRC #2930 (The Sonic Squirrels)
Andrew Chauvin will become famous soon enoughAndrew Chauvin will become famous soon enough
I am a little biased but I feel that 2930 might be a team to look for. We had a lot of radio issues at DCMP but we had a couple really good rounds, including the match I haVE LISTED BELOW
Edit: Totally didn't see John Bottenburg there, but whats a little shameless self promotion
https://youtu.be/kw1N1Z-ALUI?list=PL...LlA_rykqurjOvk
  #28   Spotlight this post!
Unread 04-14-2017, 06:29 PM
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I will totally disagree with this statement. A good ground pickup doesn't have to wait for the gear to load, the gear should be on the floor waiting for them.
"Champions are champions not because they do anything extraordinary but because they do the ordinary things better than anyone else." óChuck Knoll
  #29   Spotlight this post!
Unread 04-14-2017, 06:34 PM
EmileH's Avatar
EmileH EmileH is offline
Burnout growing nearer
AKA: Emile Hamwey
FRC #1058 (PVC Pirates)
Team Role: Student
Rookie Year: 2011
EmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond reputeEmileH has a reputation beyond repute
5687. 6-7 gears a match under no defense during week 1 at GSD, and only been improving since then.
FRC 1058 - 2016-present
FRC 3467 - 2013-2015
Check out some of 1058's Recaps here.
Member of the New England FRC community? Join the FRC New England Alliance Facebook Group!
  #30   Spotlight this post!
AustinVD_79 AustinVD_79 is offline
AKA: Austin Viens-DeRuisseau
FRC #0079 (Team 79 Krunch)
Team Role: Scout
Rookie Year: 2015
AustinVD_79 is an unknown quantity at this point
Originally Posted by CoreyBrown View Post
330 ran a 7-8 gears here https://www.youtube.com/watch?v=EmLteIbC9n8 but they also used their gear pickup so....
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
