Go to Post (psst... what's the difference between a geek and a nerd?) - sonicbhoc [more]
Unread 04-01-2003, 20:34
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Chippy (Atwood) output changed
'For starters, FIRST improved the old motors, making the bosch tougher (barring it being dropped) and by putting a usable output shaft on the Atwood motor.'
so that means we won't have that awesome cluster gear this year.....
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 04-01-2003, 21:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
that cluster gear was horrible. Just so you all know, the new output is keyed and a really nice matching coupler is provided.
Unread 04-01-2003, 21:38
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Those gears were awful. You obviously never had to grind theose things. They were made out of pressed powered bronze. You couldn't even lathe them. Not to mention how the gear was some oddball taper and size. Now you can put anything you want on the end.
Cutting the output shaft Kevin A Technical Discussion 2 18-02-2003 01:47
Chiaphua gearing (Chippy and Bosch) honky Motors 3 31-01-2002 10:28
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
question about atwood motor matt sorgenfrei General Forum 1 19-01-2002 08:31
question about atwood motor matt sorgenfrei Motors 0 18-01-2002 23:19
